gmdl-bp
darklegacy540
Member - Posts: 13
Posted: January 10, 2007 at 3:41 AM / IP Logged
This is the first time I'm installing the GMDL-BP from bypasskit.com so I have a couple questions..
I'm looking at the installation sheet and it says, "Door Trigger Output."
1. Am I supposed to be wiring the actual door trigger wire from the vehicle.. or the door trigger wire from the remote start? And if it is from the remote start, what if the remote start I'm installing, does not have a door trigger wire?
2. In regards to the Dome Light Input. The vehicle this is going into, has a dome light delay. According to Techsoft, I should be using all five wires and diode isolate each. Do I need to put in that extra work or is it okay to use the dome light wire?
Thanks in advance.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 10, 2007 at 6:32 AM / IP Logged
If you are only installing a remote start there is no connection to these wires.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 10, 2007 at 7:26 AM / IP Logged
It would help if you'd let us in on what you're installing, and into what kind of car.
darklegacy540
Member - Posts: 13
Posted: January 12, 2007 at 1:45 AM / IP Logged
2005 Chevrolet Trailblazer..
ONLY remote start and keyless.
xtremej
Gold - Posts: 1,440
Posted: January 12, 2007 at 7:52 AM / IP Logged
You don't need door trigger or domelight on that vehicle for what your doing, just RED / BLACK/ BROWN / GREEN/ blue and violet to the diagnostic plug in the vehicle. make sure to follow the programming steps.
Chris Luongo
Posted: January 12, 2007 at 8:32 AM / IP Logged
That's right. No need for the pink, pink/white, or PURPLE / white.
Chris Luongo
Posted: January 12, 2007 at 8:33 AM / IP Logged
