weak sub output
rallysport
Copper - Posts: 172
Posted: January 10, 2007 at 10:29 PM / IP Logged
i put a pioneer 3200-t amp bridged to run a JL 10w0 sub in a sealed box into my fiances 86 corolla 4 door. the amp claims to put out 150watts while bridged at 4ohms, which should be an ok match for the sub. however the bass is weak the sub moves but doesnt put out enough thump. it can barely be heard inside. the only adjustments on the amp is a LP filter on switch and the gain control which i have set properly however the little 4 and 5  inch speakers drown out the sub. the deck is a basic pioneer 1700 i remember some units need the rca output to be changed from rear to sub on some decks but the instruction manual doesnt say how (this deck may not even have that capability i am just guessing at this point) i had the sub and box in my accord about a year ago and it sounded ok and had been sitting in the closet until i installed it in this car, dotn know if that could play a part. anyway suggestions wanted!
mike12volt
Copper - Posts: 98
Posted: January 11, 2007 at 6:24 PM / IP Logged
The amp needs to be in LP. Your gain should be set to optimum sound below clipping point. The box location and speaker direction is also important.
rallysport
Copper - Posts: 172
Posted: January 11, 2007 at 6:40 PM / IP Logged
it is on LP of course i used to install for a few years. after some more tinkering it seams if there isnt enough gain adjustment. if you turn it up all the way the sub starts to come on and hit a little if you keep going to the point where the interior speakers are clipping the sub sounds better and better, maybe the deck just sucks?
aznboi3644
Gold - Posts: 2,600
Posted: January 11, 2007 at 7:10 PM / IP Logged
Um....yeah the deck sucks. Not really good quality
ituneyou
Member - Posts: 40
Posted: January 12, 2007 at 1:39 AM / IP Logged
just for kicks, have you checked if the sub is wired in phase?
A man has got to know his limitations
rallysport
Copper - Posts: 172
Posted: January 15, 2007 at 12:05 AM / IP Logged
thats the first thing i tried. im suspecting its the deck so ima try grabbing signal from the deck in my accord and see what happens
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
