Audiovox Lists:
Security
WIRE COLOR POLARITY LOCATION
Battery LT.BLU/RED (2AMP) (+) IGNITION HARNESS
Ignition 1 PINK/WHT (+) IGNITION HARNESS
Starter 1 DK. GREEN/ YELLOW (+) IGNITION HARNESS
OR STARTER BUTTON (SRT-10)
All Door Trigger MUST USE LATCH WIRES (-) BE SURE TO USE TWO DIODES TO ISOLATE
Domelight Super YELLOW/BLUE (+) DRIVERS A PILLAR
CAN ALSO BE A YELLOW/ORANGE(+)
LF Latch VIOLET (-) IN HARNESS IN DRIVERS KICKPANEL
RF Latch VIOLET/WHITE (-) IN HARNESS IN PASSENGER KICKPANEL
LR Latch VIOLET/ORANGE (-) DRIVERS KICK
RR Latch VIOLET / YELLOW (-) PASSENGER KICK
Alarm Disarm FACTORY REMOTE ONLY
Alarm Arm FACTORY REMOTE ONLY
Parking Lights WHITE/ GREEN (-) AT VEHICLE LIGHT SWITCH
PARKING LIGHTS ARE NEGATIVE TRIGGER THRU A 1130 OR 250 OHM RESISTOR. MUST USE A RELAY.
Data Bus DIAGNOSTIC PLUG UNDER DASH
Convenience
Headlights-Lo WHITE/ GREEN (-) AT VEHICLE LIGHT SWITCH
MUST USE A RELAY. HEADLIGHTS LIGHTS ARE NEGATIVE TRIGGER THRU A 660 OR330 OHM RESISTOR.
Wipers-Lo BROWN / WHT (+) WINDSHIELD WIPER MOTOR
Wipers-Hi BROWN / ORG (+) WINDSHIELD WIPER MOTOR
Remote Start
Ignition 2 PINK/GREEN (+) IGNITION SWITCH HARNESS
THERE MAY BE NO IGNITION TWO
Accessory 1 VIOLET/BROWN (-) SAME AS SECOND STARTER WIRE
SEE SECOND STARTER MULTIPLEXED DODGE RAM TECH TIP
Accessory 2 PINK / YELLOW (+) MAY BE NO SECOND ACCESSORY
THIS WIRE WILL TURN ON THE ABS LIGHT IF NOT POWERED UP FOR REMOTE START
Starter 2 VIOLET/BRN (-) IGNITION HARNESS
Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Tachometer TAN/RED, OR INJECTOR (AC) AT IGNITION COIL
ON DIESEL MODELS THE TACH WIRE IS AT THE ECM ON THE LOWER DRIVER SIDE OF THE ENGINE, FRONT 60 PIN PLUG, PIN 24 OR AT THE CAMSHAFT POSITION SENSOR, LEFT OF THE ECM AT THE 3 PIN PLUG. ON SRT-10 MODELS THE TACH WIRE IS ON THE BLACK PLUG - PIN 18.
Speed Sense GREEN/ YELLOW (AC) PCM. IN A BLACK PLUG
PIN 13. FOR SRT-10 MODELS, LOCATED IN A WHITE PLUG, PIN 27 OR OR DK.BLUE/ORANGE. DEISEL MODELS PIN 11 AT THE PCM.
Brake Lights WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights WHITE/ LT. GREEN (+) IN HARNESS, TOP OF DRIVER FENDER
Horn GREEN/ VIOLET (-) STEERING COLUMN HARNESS
OR CLUSTER,GRAY PLUG,PIN 14
Modules
WIRE LOCATION
Module 1 PCM - LOCATED ON THE FIREWALL, PASSENGERS SIDE/ DIESEL MODELS IS LOCATED LOWER DRIVERS SIDE ENGINE COMPARTMENT
Doorlocks/Windows
Door Lock Circuit ONE WIRE NEGATIVE SYSTEM (-) DRIVERS KICK
Databus Wire WHITE/ BLUE
Power Unlock VIOLET/GREEN (-) WITHOUT FACTORY SECURITY, DRIVERS KICK, 330 OHMS THRU A RELAY.
WITH FACTORY SECURITY, LIGHT GREEN/ ORANGE IN DRIVER KICK, 2K OHMS FOR LOCK, DOUBLE PULSE 480 OHMS FOR UNLOCK, MUST USE RELAYS.
PowerLock VIOLET/GREEN (-) WITHOUT FACTORY SECURITY, DRIVERS KICK, 820 OHMS THRU A RELAY.
Driver Mtr Unlock TAN/LT.GREEN
Driver Mtr Lock LT.GREEN
LF Window Up ORANGE / LT. GREEN (REV) DRIVER KICK, DOOR HARNESS
MOTOR WIRES MAY NOT REST AT GROUND
LF Window Dn ORANGE / WHT (REV) DRIVER KICK, DOOR HARNESS
RF Window Up ORANGE / TAN (REV) DRIVER KICK, DOOR HARNESS
RF Window Dn ORANGE / GRAY (REV) DRIVER KICK, DOOR HARNESS
LR Window Up ORANGE / WHITE (REV) DRIVER KICK, DOOR HARNESS
LR Window Dn ORANGE / GRAY (REV) DRIVER KICK, DOOR HARNESS
RR Window Up ORANGE / LT. BLU (REV) DRIVER KICK, DOOR HARNESS
RR Window Dn ORANGE / DK. BLU (REV) DRIVER KICK, DOOR HARNESS
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
