remote start for 98 sierra, dsl 6.5l
Welcome Guest :)
blueprint
Member -
Posted: January 20, 2007 at 9:27 PM / IP Logged
need a wire diagram to do remote start, could not locate any?
steamm
KarTuneMan
Platinum -
Posted: January 20, 2007 at 11:31 PM / IP Logged
| Wire/Function | Colour | Location/Description | Polarity |
| PASSIVE ANTI-THEFT | YES | PASSLOCK 2 | SEE NOTES |
| 12 VOLTS | Red | Ignition harness | + |
| IGNITION | Pink | Ignition harness | + |
| IGNITION 2 | Pink/white or White | Ignition harness | + |
| ACCESSORY | Orange | Ignition harness | + |
| STARTER | Yellow or Purple | Ignition harness | + |
| KEY SENSE | Lt.green | Ignition harness | - |
| TACH SIGNAL | White | At coil on engine | AC |
| | | Top of engine on passenger side |
| DIESEL TACH SIGNAL | White | At alternator on engine | AC |
| LOCK | Lt.blue | In driver's kickpanel | + |
| | | If the vehicle is equipped with a keyless entry system the doorlocks are positive trigger, otherwise they are reverse polarity. |
| UNLOCK | White | In driver's kickpanel | + |
| GLO-PLUG SIGNAL | Blue | At any glow-plug on engine or light | + |
KarTuneMan
Platinum -
Posted: January 20, 2007 at 11:32 PM / IP Logged
| DOORPIN | Purple | At light switch harness | - |
| FACTORY ARM | Equipped with PASSLOCK II | | |
| FACTORY DISARM | Equipped with PASSLOCK II | | |
| BRAKESWITCH | White | At switch above brake pedal | + |
| PARKLIGHTS | Brown | At light switch harness | + |
| HAND BRAKE | Lt.blue | On park brake bracket | - |
| HORN | Black | At steering column harness | - |
| DRIVER WINDOW UP | Dk.blue | At switch in driver's door | REV POL |
| DRIVER WINDOW DOWN | Brown | At switch in driver's door | REV POL |
| PASSENGER WINDOW UP | Blue or Blue/white | At switch in driver's door | REV POL |
| PASSENGER WINDOW DOWN | Tan | At switch in driver's door | REV POL |
| HEADLIGHTS | Yellow | At light switch harness | + |
| REVERSE LIGHTS | Lt.green | At steering column harness | + |
| DIMMER | Dk.green | At dimmer switch harness | |
| VSS WIRE | GREEN / WHITE | VCM on right side of engine compartment | |
| DATABUS INTERFACE | Pin-2(top row from left) | Diagnostic plug below dash | DATA |
| PASSLOCK DATA | Yellow | In 3 wire harness from ignition switch | DATA |
| PASSLOCK GROUND | ORANGE / black | In 3 wire harness from ignition switch | - |
Friday, May 15, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
