remote start diagram 2004 saturn ion
poundinredline
Posted: January 24, 2007 at 5:27 PM / IP Logged
i need a diagram for a 2004 Saturn Ion for a remote start. its a Directed d.i.y. remote start.
I saw the diagrams for alarms but i thought id just make sure. thanks
prdjr165
Copper - Posts: 293
Posted: January 24, 2007 at 8:53 PM / IP Logged
MODEL YEAR(S)
ION   2003 -2006
KEY T-HARNESS IMMOBILIZER
N/A    N/A    GM'S NEW PASSLOCK 2 ANTI-THEFT SYSTEM, Requires Part #XK06
PART   COLOR LOCATION DIAGRAM
12 VOLT CONSTANT   RED (+) See NOTE *1    @ BCM C1 PIN 37 and 34, See NOTE *1
STARTER See NOTE *5
STARTER 2 N/A
IGNITION 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 See NOTE *2
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 BROWN (+)   IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE SEE NOTE *2
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+)   @ HEADLIGHT SWITCH
POWER LOCK WHITE (1-Wire System) See NOTE *3   @ BCM C3, PIN 33, See DIAGRAMS   14301_ION_ION 1 WIRE JBS UNITS.pdf
POWER UNLOCK Same wire, See DIAGRAM   See DAIGRAMS   14301_ION_ION 1 WIRE ALERT SHELBY UNITS.pdf
LOCK MOTOR WIRE GRAY (+)   @ BCM, C3, Pin 51, See NOTE *1
DOOR TRIGGER SEE NOTE *4   @ BCM, See NOTE *1   26500_ION_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION WHITE (-)   @ BCM C3, IN PIN 11, See NOTE *1
TRUNK RELEASE BLACK/ WHITE (+)   @ BCM C3, IN PIN 1, See NOTE *1
SLIDING POWER DOOR N/A
HORN BLACK (-)   @ STEERING COLUMN HARNESS
TACH WHITE or ORANGE   IN PIN B or G @ MODULE, TOP LEFT OF ENGINE
WAIT TO START LIGHT N/A
BRAKE LIGHT BLUE (+)   @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM   N/A
ANTI-THEFT GM'S NEW PASSLOCK 2 ANTI-THEFT System   See DAIGRAM   26500_ION_COLORADO-CANYON PASSLOCK 2 BYPA.pdf
NOTES
NOTE *1 THE BCM (Body Control Module) IS PART OF THE FUSE/RELAY BOX IN THE LOWER CENTER OF THE DASH,JUST BELOW THE HVAC CONTROL ASSEMBLY.IT HAS THE FOLLOWING CONNECTORS:C1-37 PIN BLACK PLUG,C2-38 PIN GRAY PLUG,C3-56 PIN BLACK PLUG,C4-56 PIN GRAY PLUG,AND C5-6 PIN GRAY PLUG.
NOTE *2 THE ECM (Electronic Control Module) IS ON THE DRIVER SIDE OF ENGINE COMPARTMENT,NEAR COOLANT OVER FLOW CONTANIER.THERE IS A WHITE WIRE AND A WHITE/ BLACK WIRE AT THE IGNITION HARNESS THAT PERFORMS KEY SENSE, SECOND IGNITION, STARTER AND PASSLOCK. SEE DIAGRAM FOR REMOTE START INFORMATION.
NOTE *3 LOCK IS A STRAIGHT (-) NEGATIVE TRIGGER. UNLOCK IS A NEGATIVE THRU 1.5K OHM RESISTOR, IF THE UNIT DOES NOT HAVE ON BOARD DOOR LOCK RELAYS, EXTRA RELAYS PART #775,WILL BE REQUIRED, See DIAGRAMS.
NOTE *4 THE DRIVERS DOOR TRIGGER IS LIGHT GREEN/ BLACK (-) IN PIN 45 AND THE PASSENGER DOOR(S) IS LIGHT BLUE (-) IN PIN 44. WHEN CONNECTING TO AN ALARM SYSTEM USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, SEE DIAGRAM.
NOTE *5 This vehicle requires a special PASSLOCK 2 Bypass module Part #XK06 to order contact DIRECT WHOLESALE at 1-800-659-0764
LINK 1 LINK TEXT 1 LINK 2 LIN
Friday, January 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
