autopage rs660 remote start
airshives23
Member - Posts: 17
Posted: January 27, 2007 at 4:17 PM / IP Logged
ok, this remote start to my knowledge does not have a wire for a 2nd accessory, however, i was told that my 99 alero needs to have a 2nd accessory wire hooked up to get the unit to activate.  how do u get a system w/ only 1 accessory hookup to utilize a 2nd?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 27, 2007 at 9:52 PM / IP Logged
Use the first accs. wire from the remote start to trigger an extra relay for second accs.
Ground to 86, 12volts fused to 87, your 1st ign. to pin 85, (as well as to your ignition wire on your rig) pin 30 goes to the second ign.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
