wiring 1 jbl gto1202d
iv4n
Posted: January 29, 2007 at 9:47 PM / IP Logged
Hi, im wiring 1 Dual Voice Coil Subwoofer with Dual 2 ohm Voice Coils
JBL GTO1202D ( http://jbl.com/car/products/product_detail.aspx?prod=GTO1202D&Language=ENG&Country=US&Region=USA&cat=SUB&ser=GTS )
My question is.. will a Boss CH-700 ( http://www.bossaudio.com/home/catalog/public_html/print/productSpecDetails.php?product_id=363 ) do the job correctly connecting the 2 channels bridged with the subwoofer coils connected in series? Thanks
Im not sure because of the ohm load and that thing, because i think it will have a 4 ohm load and im sure if i connect the amp in bridge mode it will give 400 RMS at 4 ohms
specialaudio
Copper - Posts: 58
Posted: February 04, 2007 at 11:33 AM / IP Logged
how is that sub treating you?
93' Cutlass
haemphyst
Platinum - Posts: 5,059
Posted: February 04, 2007 at 12:39 PM / IP Logged
Wire one channel to eah voice coil. It's the VERY same power (specified by Boss as 600wpc, but more likely 100wpc - if that, in the real world) to the woofer as your suggestion. Otherwise, yes, you can wire the coils in series, then bridge the amplifier. It should be a safe load for the amplifier.
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
