looking for overhead dvd console
paul13_1
Posted: January 31, 2007 at 4:24 AM / IP Logged
I am looking for an overhead dvd console for my 2006 chrysler town and country. Its not the touring or limited model, its the LX. I also have several questions on installing it with the overhead rear air controls. Any help would be better than where I am right now. Thanks.
Platinum - Posts: 12,488
Posted: January 31, 2007 at 7:12 AM / IP Logged
I believe Audiovox has an overhead unit that will work perfectly for this vehicle. Not sure of the part number but it does have the dome light and is short enough to not interfere with the rear controls.
Mike M2
Platinum - Posts: 2,652
Posted: January 31, 2007 at 8:50 PM / IP Logged
Avox makes one, it relocates the air controls back further. Do a search for part number 1187255PL  or 1187254PL and you will find it. These are for no sunroof, no rail system. The first one is for larger screens. Both will require an insert which fits into the center of the console.
Mike M2
Tech Manager
CS Dealer Services
NowYaKnow
Gold - Posts: 1,217
Posted: January 31, 2007 at 10:40 PM / IP Logged
Yeah the Audiovox one works great if you don't mind using an Audiovox tv as well. It can be a pain trying to get slack on that air control harness, but you can usually get just enough out of it. I have also installed tvs w/o a console on either side of the rear air controls per customer request. Works out pretty well also just doesn't look as good.
Mike
paul13_1
Posted: February 01, 2007 at 12:58 AM / IP Logged
I was also wondering about the ducts for the rear air. Will they be anywhere near where this console goes? And do you usually just get the 12 volts from the air controls or try to bring a new wire for circuit by itself? Hope I'm not bothersome but I have alot of questions and thanks for the replys already!!
Mike M2
Posted: February 03, 2007 at 11:54 AM / IP Logged
No air ducts in the way, the kit fits well from Avox. Get power from the dash....
Mike M2
Tech Manager
CS Dealer Services
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
