2007 dodge durango wiring guide
startersllc
Posted: February 01, 2007 at 12:40 PM / IP Logged
I have a small company that does remote start installs for local dealerships. I got a call a couple days ago to install a remote start in a 07 Dodge Durango. I agreed and brought an 06 Durango wiring guide with me because I couldn't find an 07 guide. When I got there I couldn't find any of the wires and I didn't get any help from the service department. I called the company that I get my guides from and they said one hasn't been released yet. Does anyone know where to get a guide for the 07 Durango?
Twelvoltz
Platinum - Posts: 2,384
Posted: February 01, 2007 at 1:42 PM / IP Logged
Audiovox lists:
          #511854: 2007 DODGE DURANGO 4DR SUV WITH 3.7L ENGINE AND STANDARD AUDIO SYSTEM
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / ORANGE & RED / BLUE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK/LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          PINK/LT. BLUE          (+)          IGNITION SWITCH HARNESS, MAY NOT BE ON ALL VEHICLES
     All Door Trigger          USE LATCH WIRES
     Domelight Super          YELLOW/ORANGE          (+)          AT COURTESY LIGHT UNDER DASH
     LF Latch          VIOLET/          (-)          THESE WIRES MUST BE DOUBLE DIODE ISOLATED
               AT THE 74 PIN PLUG NEER THE FUSEBOX. IF THE VEHICLE HAS MEMORY SEATS THE FRONT DOOR WIRES ARE IN EACH DOOR AT THE DOOR MODULE.
     RF Latch          VIOLET/WHITE          (-)          THESE WIRES MUST BE DOUBLE DIODE ISOLATED
     LR Latch          VIOLET/GRAY          (-)          THESE WIRES MUST BE DOUBLE DIODE ISOLATED
     RR Latch          VIOLET / YELLOW          (-)          THESE WIRES MUST BE DOUBLE DIODE ISOLATED
     Trunk Trigger          VIOLET/ORANGE          (-)          AT THE 74 PIN PLUG NEER THE FUSEBOX UNDERDASH
     Hood Trigger          VIOLET/BLUE          (-)          AT PINSWITCH UNDERHOOD
     Alarm Disarm          FACTORY REMOTE
     Alarm Arm          FACTORY REMOTE
     Parking Lights          SEE NOTE
               RUN A WIRE TO PIN #85 AT THE PARKING LIGHT RELAY UNDER THE HOOD. TURN ON THE PARKING LIGHTS TO LISTEN FOR THE RELAY TO CLICK.
     Low Crr Pk Lights          PINK/RED          (-)          SEE NOTE
               REQUIRES A 1.1K-OHM RESISTOR TO ACTIVATE PARK LIGHTS. YOU MUST OPEN THE WIRE WITH A RELAY WHEN SENDING YOUR RESISTANCE DOWN THE VEHICLE SIDE OF THE WIRE.
     Data Bus          PIN-2 (TOP ROW FROM LEFT)          DATA          DIAGNOSTIC PLUG BELOW DASH
     Convenience
     Headlights-Lo          PINK/RED          (-)          AT VEHICLE LIGHT SWITCH HARNESS
               REQUIRES A 650-OHM RESISTOR TO ACTIVATE HEADLIGHTS. YOU MUST OPEN THE WIRE WITH A RELAY WHEN SENDING YOUR RESISTANCE DOWN THE VEHICLE SIDE OF THE WIRE.
     LF Pk Lt Bulb          PINK/RED          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          WHITE/ TAN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          PINK/RED          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          WHITE/ TAN          (+)          AT REAR RIGHT PARKING LIGHT
     LF Hazrd Bulb          WHITE/ LIGHT GREEN          (+)          AT FRONT LEFT DIRECTIONAL LIGHT
     RF Hazrd Bulb          WHITE/ ORANGE          (+)          AT FRONT RIGHT DIRECTIONAL LIGHT
     LR Hazrd Bulb          WHITE/ LIGHT GREEN          (+)          AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb          WHITE/ ORANGE          (+)          AT REAR RIGHT DIRECTIONAL LIGHT
     Parking Brake          DK. GREEN / WHITE          (-)          AT SWITCH
     Remote Start
     Ignition 2          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          PINK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 2          PINK / YELLOW THIN GAUGE, OR BLUE          (+)          IGNITION SWITCH HARNESS
               MAY NOT BE PRESENT ON ALL MODELS
     Starter 2          VIOLET/LT. BROWN          (-)          IGNITION SWITCH HARNESS, SAME AS KEY SENSE
               FOR REMOTE STARTS USING AUDIOVOX UNITS, CONNECT TO BLACK / YELLOW WIRE FROM THE FOR PIN CONNECTOR.
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          VIOLET/LT. BROWN          (-)          IGNITION SWITCH HARNESS
     Neutral Safety          YELLOW          (+)          AT GEAR SELECTOR SWITCH
     Tachometer          USE INJECTOR
     Speed Sense          WHITE/ ORANGE          (AC)          IN HARNESS ON INTERIOR DRIVERS SIDE OF FIREWALL
     Low Crr. Pk Lights          PINK/RED          (-)          SEE NOTE
     Brake Lights          WHITE/ TAN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ GREEN          (+)          IN BLACK PLUG AT FUSEBOX
     Horn          GREEN/ VIOLET          (-)          AT STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Databus Wire          PIN-2 (TOP ROW FROM LEFT)          DATA          DIAGNOSTIC PLUG BELOW DASH
     Power Unlock          VIOLET/LIGHT GREEN          (-)          SEE NOTE
               GROUND THROUGH 110 OHM RESISTOR TO UNLOCK. GROUND THROUGH 330 OHM RESISTOR TO LOCK DOORS. VEHICLES EQUIPED WITH MEMORY SEATS THESE WIRES ARE IN THE DRIVER DOOR. WITHOUT MEMORY SEATS, THESE WIRES ARE FOUND ON A WHITE PLUG NEER THE FUSEBOX.
     PowerLock          VIOLET/LIGHT GREEN          (-)          SEE NOTE
     LF Window Up          WHITE/ BLUE          (REV)          AT SWITCH IN DRIVER DOOR
     LF Window Dn          ORANGE / WHITE          (REV)          AT SWITCH IN DRIVER DOOR
     RF Window Up          WHITE/ GREEN          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     RF Window Dn          ORANGE          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     LR Window Up          BLUE/GREEN          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     LR Window Dn          BLUE/PINK          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     RR Window Up          BLUE/ORANGE          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     RR Window Dn          PINK/RED          (REV)          AT HARNESS FROM DRIVER DOOR KICKPANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
