heater not coming on w/ r/s
dashiznit666
Posted: February 02, 2007 at 11:56 PM / IP Logged
I have a 2001 ford mustang V6 3.8L and when i first installed my R/S i hooked the accessory wires up wrong so the heater didnt work  at all.. so i rechecked everything and found the reason it wasnt workin... i hooked the accessory wires up correctly and the heater started working like it should with the R/S but now all of a sudden it snot working again!! can someone tell me why it stopped working all of a sudden??  and if someone knows where i can get wiring diagram for my car id really appreciate it!!!
superman1218
Member - Posts: 13
Posted: February 03, 2007 at 12:33 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / MUSTANG / 2001 / Remote Start
[PRINT THIS PAGE]
12volts yellow & lt. GREEN/ purple  +  ignition harness
Starter WHITE/ pink  +  ignition harness
Second Starter N/A
Ignition RED / lt. green  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW and RED / black  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense BLACK/ pink  -  ign harn, 26 pin plug, pin 9 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Lock lt. green  +  20 pin plug, pin 20 at GEM
Power Unlock purple  +  20 pin plug, pin 18 at GEM
Lock Motor RED / white  5wi 20 pin plug, pin 9 at GEM
Unlock Motor RED / orange  5wi 20 pin plug, pin 7 at GEM
Parking Lights+ brown  +  26 pin plug, pin 7 at GEM
Parking Lights- WHITE/ black  -  26 pin plug, pin 11 at GEM
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org(R)  +  steering column
Turn Signal(R) wht/lt blu(F), org/lt blu(R)  +  steering column
Reverse Light BLACK/ pink  +  26 pin plug, pin 20 at GEM
Door Trigger yel/black (L), gray/red (R)  -  20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ white  +  20 pin plug, pin 3 at GEM
Trunk/Hatch Pin BROWN / white  -  12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin N/A
Trunk/Hatch Release pink/lt. green  -  26 pin plug, pin 25 at GEM
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm dk. GREEN/ purple  -  20 pin plug, pin 16 at GEM
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or WHITE/ lt. blue  ac  ignition coil or coil pack
Wait to start N/A
Brake Wire RED / lt. green  +  brake pedal switch
Parking Brake purple / YELLOW or lt. blu/blk  -  12 pin plug, pin 4 at GEM
Horn Trigger yellow/lt. green  -  26 pin plug, pin 12 at GEM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
heater not coming on w/ r/s -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PATS
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 555PW/555FW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: When using the 1100X, a software change to 1100FM is needed.
superman
dashiznit666
Posted: February 03, 2007 at 7:50 AM / IP Logged
on my ignition harness there is like 2 BLACK/ lt. green wires, 2 grey / YELLOW wires, and i think theres also 2 RED / lt. green wires... are the pair of wires for the same thing or is like one grey / YELLOW totally different from the other grey / YELLOW??  and if they are different how do i tell which is which?? like my accesory wire is grey / YELLOW according to that diagram.... well theres 2 grey / YELLOW wires so which one do i use and how do i know whats what??
dashiznit666
Posted: February 03, 2007 at 11:21 AM / IP Logged
ok on the ignition harness there are 3 yellow wires, 2 grey / YELLOW wires, 1 RED / black, 1 BLACK/ green, and 2 light GREEN/ purple wires, and one WHITE/ pink but thats the starter wire!!! the diagram says for accessory 1 = gray / YELLOW and RED / black, and for accessory 2 = BLACK/ light green.... so my question is, do i need to hook up those 2 wires for accessory 1 and the BLACK/ green for accessory 2?? and if i have to hook up both for accessory one... which one of the 2 gray / YELLOW wires do i use or do both need to be used???
