big three ground wiring, optima dual post
cim2phat4u
Member - Posts: 22
Posted: February 03, 2007 at 3:56 PM / IP Logged
Instead of running a new cable from battery-ground-to-chassis and from alternator-ground-to-chassis, wouldn't it be better to simply run a new cable directly from alternator-ground-to-battery-ground (so it becomes a Big Two upgrade).  Is this ok and just as good as the normal Big Three upgrade?
Also, for Optima batteries with both side and top posts, is it perfectly fine to use all four posts simultaneously and interchangeably (while maintaining correct polarity of course).
Thanks in advance
DYohn
Platinum - Posts: 10,741
Posted: February 03, 2007 at 4:18 PM / IP Logged
While not a bad thing to do, battery-to-alt ground is not the same thng at all, since your amps will be grounded to the chassis you need to upgrade the returns from the chassis to the source.
aznboi3644
Gold - Posts: 2,600
Posted: February 03, 2007 at 5:33 PM / IP Logged
It is perfectly fine to utilize all posts...makes the terminals less cluttered
layinframe_95
Member - Posts: 32
Posted: February 04, 2007 at 3:03 PM / IP Logged
Just going Alt to Batt. will probably hurt your amp and other body grounds...  Upping your chassy to -Batt will only help because ALL of your electrical components groud to your chassy, NOT your alternator...
the12volt
Administrator - Posts: 3,959
Posted: February 04, 2007 at 3:12 PM / IP Logged
Not true. No harm will come to your amp or other body grounds as a result of just upgrading the lead from the alternator to the battery.
Again, not true. When the vehicle is running, absolute ground is at the case of the alternator.
big three ground wiring, optima dual post -- posted image. the12volt • Support the12volt.com
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
