ppi art series ax 606.2
caddytruck
Member - Posts: 6
Posted: February 03, 2007 at 5:20 PM / IP Logged
Hello, this is my first post so take it easy on me. I have some questions about wiring and impedance loads. First of all the front two channels and two rear channels are bridgable to 4 ohms. (typicle) here is were it gets tricky, my boston pro series components are 3 ohm. Can i get away with bridging the front and rear channels to 3 ohm mono? Also the subwoofer channels are rated to run 1 x 400 at 2 ohm bridged. if i run one dual 4 ohm voice coil sub in parallel to get a 2 ohm load is my amp seing it at  2 ohms? Or by bridging it do the two sub channels now see it at 1 ohm?
roo-dog
Copper - Posts: 124
Posted: February 03, 2007 at 8:09 PM / IP Logged
running  the 4 ohm dvc sub in parallel will give you 2 ohm mono load off of subwoofer channel of amp.  shouldn't be a problem.  you can always test the speaker wire leads coming off the box using an ohm/ multimeter-preferably digital.  this will give you an actual reading of ohms.  not a bad idea before turning on the juice, to make sure all wiring is correct.  some speakers actually run at a slightly different impedence than advertised-  usually not a problem. (example-12"pioneer spl3002 dvc 4 ohm subs:actually sit at 3.6ohms per coil)
as for the front channel question;  i am not particuliarly experienced with this amp.  i will leave that up to someone else who is to answer.  (I would probably test the leads for actual impedance, and based on the results-make an educated guess as to if it seems ok to do.) i don't want to give you bad info-wait for another opinion before trying.    hopefully i was helpful.
(4)g5-1244, (4)gtr12, (2)ppipcx2400, (1)pcx4125, (1)pc4800.2, (3) pair mb quart 6.5"Q, (4)optimas, alumapro (1)5 and(1)15 farad cap, premier deh-p860mp, pioneer xm -dual H.O. alternators
caddytruck
Member - Posts: 6
Posted: February 04, 2007 at 7:34 PM / IP Logged
Very helpfull mr. dog. Does anyone else run boston acoustic pro's? If so how are you wiring them? They are 3 ohm. Is everybody running 3 ohm stereo? I want to bridge them but i'm not sure I should run them at 3 ohm mono?
roo-dog
Copper - Posts: 124
Posted: February 08, 2007 at 7:57 AM / IP Logged
  ok, talked to a couple of people-  they all say DO NOT run that amp at 3 ohm mono, just have to run it stereo-if not enough power, will have to change up to a different amp.  the other possibility is;  can you bi-amp those separates?  i know with the new ones you can run two channels to the tweeters and two channels to the mids.  there would be a little more fine tuning involved (separate gain control of tweeters and mids), but you may be able to get a better sound out of it.  and, i would think it should be plenty loud enough also.    i think that is all i hae to offer right now, let me know if any questions-glad to help.
caddytruck
Member - Posts: 6
Posted: February 08, 2007 at 1:30 PM / IP Logged
If i bi-amp the components can i use the boston crossovers?  or should i just use the 456 crossover that is in my amp??? or both? I have a 2006 chevy hhr,all black 20in chrome wheels, pretty cool family car! Would you use any rear fill? (in the rear doors) I have got many difffrent opnions about this.
roo-dog
Copper - Posts: 124
Posted: February 08, 2007 at 5:54 PM / IP Logged
ok- so, if you are going to bi-amp the ba's;  the ba crossovers will take care of the high pass filter that is necessary to protect the tweeters, as well as the low pass filter that is necessary for the mids.  the only thing left would be to set a high pass filter on the mids (probably use the one on the amp or head unit-around 80hz or so. i usually set according to how it sounds and how the speakers respond.  too low of a filter will send too much bass to mids, making them distort/possibly damaging them: too high of a filter will cause you to lose some notes and sacrifice the sound that you hear)  the only thing left would be to set that filter on the mids, maybe not a bad idea to set the same filter on the tweeters also- but it shouldn't make any difference, like i said, the ba x-overs should take care of it.  i would set them both the same, even if you hear no difference.  and using a bi-amp setup, you can adjust the gain controls of the front/rear of the amp to control the desired loudness of the tweets and the mids.
rear fill?   well, i have always stacked up multiple pairs of rears and just ran one pair of fronts. (i always use overkill as a standard-lol)  this time, i am running three pairs if front separates, and only two pairs of coax's for rear fill.  i like this imaging better-more capturing, rather than just "blown away loud".      rear fill does help -a lot.   but, i don't feel it is as important as the front.  pretty much anything will help.  you can spend a lot of money, but you don't have to.  even just a pair of decent coaxials will greatly add to your imaging.  even if they don't see the same wattage as the fronts, or if they aren't as big in size as the fronts. anything will help.  ex- my sisters boyfriend has a pair of sep's up front off of an amp (chevy truck), and i threw a pair of 4x6" plates in his rear doors, running off the amp in his head unit-  sounds great.  not as loud as fronts, but enough for fill.    a lot of choices, all of them are what YOU prefer.  (i like having 32 speakers with 7000watts going to them in my extended cab pickup-no room for a family-lol!)
hopefully this is helpful- ask on if anything else.    and. YES, does sound like a fun family vehicle(lol) .  nothing wrong with looking good with the family.
caddytruck
Member - Posts: 6
Posted: February 08, 2007 at 7:53 PM / IP Logged
Thanks again dog. Do you have any suggestions on a sub to run?? I 'm a jl audio guy, usually. was thinking 8 w7 or ?
roo-dog
Copper - Posts: 124
Posted: February 09, 2007 at 7:28 PM / IP Logged
subs?  well, i have been kindof stuck in one corner on that end of the market. for the past 5 years i have run strickly pioneer premier subs.  i had four of the old ones with the 5 diamonds on the cone (model?). then i had two of the yellow spl ones.  then i had 2,12 inch-tsw-spl 3002/ and 2-10 inch spl-2504's, all running together in one custom box; the 12's running low pass at about 55 hz, and the 10's running bandpass at 55hz to about 100 hz,  they made for a real  concert sound.  now, i run 4-boston acoustic 12"g-5 subwoofers, with 4 boston acoustic 12"gtr radiators (passive subs) in the same box.  it sounds awesome! tight, hard, loud, and low-sub frequencies!     they also make them in 10 inch sizes too.  very small enclosure sizes (1.0 cu. ft for 12's, .5 cu. ft for 10's) and you can just add a passive to the same box without losing power handling-just sounds like you added another 1/2 of a sub)  the only drawback is the large magnets on the speaker.  and, if you blow them up, you can buy replacement parts to completely rebuild the sub for about 100 bucks.   if mounting depth is an issue.  if so, you should check out the pioneer premier sd(?) series subs.  they are made in tens, and 12's, require a small enclosure, and have somewhere around 3 and 1/2 inch mounting depth.  i put two twelves in an s-10 standad cab pickup! they aren't spl type subs, but do handle 1400 watts, and have a very deep, pleasing sound.
jls are nice, too.  just haven't had too much personal experience with them.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
