05/06 parking light wire grand cherokee
acebandit_21
Member - Posts: 13
Posted: February 05, 2007 at 2:51 PM / IP Logged
Is there any way to wire the R/S Parking light  wire into the Headlights or Lowbeams even,maybe??... I know that most people just use the 4way lights for  this wire on these vehicles, but that Flashing isn't all that appealing to me... Even if I have to relay up something or run additional wires to get the "actual parking lights" to work with the R/S unit, ill do it.. i just dont want that flashing... Also I was just wondering, what exactly is the reason that install sheets say to NOT use the wire?? Any help on this issue would be appreciated...  Thanks Guys.....
I can accept failure. But I can't accept not trying.   -Michael Jordan
lsondubz
Copper - Posts: 193
Posted: February 05, 2007 at 3:44 PM / IP Logged
IYou could try to run a 12V wire right to the parking light harness AT the headlight..
acebandit_21
Member - Posts: 13
Posted: February 05, 2007 at 4:11 PM / IP Logged
Ok ISO.. do you know if it has one harness for BOTH headlights OR is it one harness for EACH headlight??
f150fan
Copper - Posts: 95
Posted: February 05, 2007 at 6:45 PM / IP Logged
One thing you can do is go under the hood into the fuse panel that houses all of the relays and test the parking light relay. Either 85 or 86 (I'm pretty sure it is 85) will test negative when the parking lights are turned on. From there you can solder the negative parking light output on to that terminal of the relay and it will power all of the parking lights.
acebandit_21
Member - Posts: 13
Posted: February 06, 2007 at 8:02 AM / IP Logged
Thanks F150,  Im deffinitely gonna add that onto my list of things to try.... Any other takers??
