wiring neon lights to a switch
jbizzle36
Posted: February 07, 2007 at 5:53 PM / IP Logged
I have neon lights that i want to wire to a switch and everytime i look a the back of the switch i just get kinda lost, how do i do this?
Girls Second, Cars first
KPierson
Platinum - Posts: 3,527
Posted: February 08, 2007 at 7:50 AM / IP Logged
Simply run the power wire to the transformer through the switch.  Depending on the type of switch you have there could be multiple configurations.  What type of switch are you using?  Most likely you'll cut the power wire to the transformer and run one side through the C terminal and the other through the NO terminal.  If there are only two terminals on the switch it won't matter how you hook it up.  If there is a light in the swtich then things get a bit more complicated as you need to make sure your 12v feed is on the 'in' side and that the switch is grounded for the light to work.
Most importantly, make sure the transformer is fused at the power end of the wire.  I almost caught a customers car on fire one day because he 'installed' a switch for his neon lights in between his lower dash and steering column.  When I lowered his under dash the switch fell (I didn't even know it was there) and hit the metal brace under the dash.  There was no fuse so when it shorted out the wire heated up and almost caught on fire.
Kevin Pierson
bs63366
Posted: March 02, 2007 at 1:56 PM / IP Logged
Just go to like radioshack and get a SPST (Single Pole Single Throw) switch this is the one that only has 2 terminals on it and just cut your power wire and run the switch in line with it
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
