ford five hundred factory disarm
racerrx-3
Member - Posts: 12
Posted: February 10, 2007 at 12:46 PM / IP Logged
OK,
Ford Five Hundred and cant locate factory disarm wire.....   Supposed to be Con C - PIN 4 at SJB, there is no lt blue/black.  No such wire found in Dr. door kick.  Checking all the wires for - pulse on disarm and coming up with nothing.....
Thanx in advance for help!
Charlie
Alternative Auto
mikvot
Gold - Posts: 1,043
Posted: February 10, 2007 at 1:24 PM / IP Logged
are you sure it has an alarm.....i do 500's every day and never had a prob finding the factory disarm. I usually get it at the very bottom of the junction box.....there are two connectors, it will be in the left connector.
Mike M2
Platinum - Posts: 2,652
Posted: February 10, 2007 at 1:34 PM / IP Logged
I just did one too and it was right in the drivers door harness in the kick panel....
Mike M2
Tech Manager
CS Dealer Services
mikvot
Gold - Posts: 1,043
Posted: February 10, 2007 at 1:52 PM / IP Logged
yep, you can also get it there.....thats how i used to do them, before i found everything at the junction box.
racerrx-3
Member - Posts: 12
Posted: February 10, 2007 at 2:22 PM / IP Logged
OK?
Thanx, found the wire.  Although how did you guys check the wire.  Nothing reads on multi?  I used test light to transfer pulse (-) just in case, that worked but not ideal.....
Thanx,
Charlie
Alternative Auto
mikvot
Gold - Posts: 1,043
Posted: February 10, 2007 at 2:27 PM / IP Logged
to test, put the key in the door cylinder.....when you unlock with the key it will give you a neg. pulse.
racerrx-3
Member - Posts: 12
Posted: February 10, 2007 at 3:39 PM / IP Logged
AAAHHHHH...
Knew I was missing something.....  I lost a couple of dollars in time, but it's Saturday and were closing.  Thanx again........
