another wire size list
destro3306
Posted: February 22, 2007 at 6:33 PM / IP Logged
From the battery to the d-block, what size wire should be used if the amplifier(s) maximum draw is 300 amps?
I will run (3) 4g wires to the three amps from the d-block.
Can the amplifiers be grounded without the need for a ground d-block? I was thinking about just grounding the (3) 4g grounds normally (without block)..
Thanks!
stevdart
Platinum - Posts: 5,816
Posted: February 22, 2007 at 6:39 PM / IP Logged
https://www.the12volt.com/info/recwirsz.asp
1/0 gauge.  Yes, you can ground each amp individually to the chassis floor pan.
destro3306
Posted: February 23, 2007 at 7:23 PM / IP Logged
Thanks man.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
