Bazooka RSW1024DVC Ask?
Sebastian018
Silver - Posts: 364
Posted: February 05, 2003 at 9:09 AM / IP Logged
HI, I have two Bazookas RSW1024DVC  DVC in a bandpass box and Two bazookas ELW1014 Single in Two Tubes. the two ELW1014 are connected to One amplifier two channels 600W, they work great and my question Is having a Profile California two channels 600W, Can I just wire one coil of the sub and leave the another coil of the sub alone, Or I will sound better is I connect it Parallel Wired connecting the plus terminal of the Bazooka DVC connected to the plus terminal of the other terminal, same with the negative..
bberman1
Gold - Posts: 2,314
Posted: February 06, 2003 at 5:37 PM / IP Logged
Are you sawing you only want to run 1 voice coil on each DVC sub? If so its not possible well actualy it is. But if you do that you will destroy the sub in a matter of  a few days. on a DVC you must run both coils.
Sebastian018
Silver - Posts: 364
Posted: February 06, 2003 at 6:06 PM / IP Logged
OK, And how do I run Both Coils?
bberman1
Gold - Posts: 2,314
Posted: February 06, 2003 at 7:53 PM / IP Logged
Just read my post sorry about the spelling errors. What are the ohms on your subs and what’s the lowest independence (ohms) your amp can handle.
Sebastian018
Silver - Posts: 364
Posted: February 06, 2003 at 7:56 PM / IP Logged
I was checking my amp and you can connect it 2ohms Stable Stereo and its two channel, the Bazookas DVC are 4 ohn I could connect parallel Positive of One terminal to positive of the other terminal then one to the positive amp same with the negative so I will have 2Ohm stable right?
bberman1
Gold - Posts: 2,314
Posted: February 06, 2003 at 8:12 PM / IP Logged
Correct if you wire them in parallel that will give you a 2 ohm load on each channel of the amp.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
