wiring 3 amps in minivan
piston_hrc
Member - Posts: 8
Posted: February 26, 2007 at 11:32 PM / IP Logged
Hey, new guy here... just joined and looking for input on a setup im building.
Its all going in a '95 voyager with a 110a alternator, 8 ga wire directly to the battery which is new also.
Amps are Infinity 611A (2) and a Infinity 7541 (1)
I bought a 5 farad cap a week ago, before finding this forum and seeing how you guys "love" caps LOL!!
So im thinking, sell the cap before it ever gets used, add a second battery with an isolator.  Would that be the best route? would you do anything more/different if it were yours?
Thanks for any input you can offer :)
rudydapimp
Copper - Posts: 390
Posted: February 27, 2007 at 7:48 AM / IP Logged
I would step up to at least 4 gauge, and put a distro block in the rear at have outputs of 8 gauge for the amps (since you already have it), i personally would just run 0 gauge back and then 4 gauge to the amps. You are going to need an extra battery, and i would also upgrade the "big 3"
piston_hrc
Member - Posts: 8
Posted: February 27, 2007 at 8:30 AM / IP Logged
Big 3 has been done, I've already got the amps installed and running right now.  Would I want to run a 4ga wire off the isolator to the extra battery in the back, then tie each amp directly off the battery..  leaving the vehicle's electrical completely seperate?
j_darling2007
Copper - Posts: 210
Posted: February 27, 2007 at 5:52 PM / IP Logged
I have a 611a amplifier. It is very power hungry at 60 amps. If I were you, I would use a minimum of 0 gauge, and, if your budget allows, a high output alternator.
There are 3 kinds of people in the world, those who can count and those who can't
piston_hrc
Member - Posts: 8
Posted: February 27, 2007 at 8:43 PM / IP Logged
I think I'll go ahead and do  4 gauge from the isolator block to a Optima yellow top located in the back. Then run 0 gauge from there to a distro block.  Also going to upgrade to a 180a alternator
I've noticed that with these amps. They seem to do just what I want but you can tell they are starving for power at times.
aznboi3644
Gold - Posts: 2,600
Posted: February 27, 2007 at 11:20 PM / IP Logged
I'd suggest a 0 gauge run from the front battery to the rear battery
piston_hrc
Member - Posts: 8
Posted: February 28, 2007 at 7:09 AM / IP Logged
If I run a isolator block, the most that will travel through the front/back cable will be 110A (alternator output). It won't be connected directly to the main front battery.  Would 4ga not be enough for that?
Thanks for all your help with this, I definatly want to build it right the first time.
haemphyst
Platinum - Posts: 5,059
Posted: February 28, 2007 at 10:16 AM / IP Logged
FORGET the isolator. Run the batteries (hopefully identical) in parallel, with a #4 between them (and a 150A fuse at BOTH ends!) and then run all your power for the amplifiers from the back battery, right off the terminal. You will need an upgraded alternator, no question, and I'd suggest the biggest one you can find. If your present alternator is 110A, then you are already looking for trouble using a #8, that's not big enough. Upgrade your alternator cable to #4 to start.
piston_hrc
Member - Posts: 8
Posted: February 28, 2007 at 7:56 PM / IP Logged
I was afraid of ruining a battery due to overcharging without an isolator, but with the same batteries it should be ok for a while I guess?
Maybe a couple of good interstate batteries will do the trick. Not sure I can swing 400 bucks for Optima's ;)
aznboi3644
Gold - Posts: 2,600
Posted: February 28, 2007 at 11:37 PM / IP Logged
overcharging without an isolator?? why would you think that
if that were true than everyones battery under their hoods would be overcharging
