how do you test amplifier output wattage
cim2phat4u
Member - Posts: 22
Posted: February 27, 2007 at 8:34 PM / IP Logged
Hey, I have a voltmeter and I know that P=IV. I want to find out roughly what my amplifier's output wattage looks like when music and test tones are playing, and compare it to the rated power handling of my speakers. Basically I want to know how much wattage is used to produce a certain level of performance/loudness in my system, and how much headroom my speakers have as I change the gains. What's the best way to do this?
I figure I could just disconnect the speaker from the amp and put the voltmeter across the +/- speaker terminals on the amp and play some tones. This voltage should get bigger with louder tones or sounds right? But having a rough idea of the voltage, what current do I use to calculate the actual wattage that would normally be going into the speakers?
Thanks in advance
coppellstereo
Silver - Posts: 785
Posted: February 27, 2007 at 8:52 PM / IP Logged
you will start by using AC current
DYohn
Moderator - Posts: 10,741
Posted: February 27, 2007 at 9:45 PM / IP Logged
haemphyst
Platinum - Posts: 5,059
Posted: February 27, 2007 at 10:23 PM / IP Logged
DYohn wrote:
http://www.bcae1.com/measpwr.htm
Dave, Dave, DAVE... you would send business to a competitor? how do you test amplifier output wattage -- posted image. I prefer this calculator. You can find the voltage, you KNOW the impedance, so it'll be easy. In your case, you'd use voltage squared, divided by resistance, to arrive at power.
cim2phat4u
Member - Posts: 22
Posted: February 28, 2007 at 12:54 AM / IP Logged
Hmm I was just thinking... since P = I*V = I*I/R, that means that at the same power, increasing the resistance means decreasing the current. Therefore, suppose I want to drive a subwoofer with 1000 Watts. Then using a 4 ohm sub would demand less current than a 2 ohm sub, though both are putting out 1000 Watts worth of sound power. Does this mean you shouldn't need as powerful an alternator if you were running a 4 ohm sub? And on top of that, running it at 4 ohm is supposed have better sound quality? I think I must be missing something, or else why wouldn't everybody use high resistance speakers which would minimize current draw and improve sound quality?
I know that you would need to upgrade the amplifiers to achieve the same power output at higher resistance, but on the other hand you decrease the current draw which means you don't need to upgrade the alternator as much. So if you wanted to run a sub at a particular high wattage (suppose 1000 watts rms), either way you have to choose whether to buy a new amplifier or new alternator. Since a sub at 4 ohm is supposed to produce better sound quality than at 2 ohm, and also since a new amplifier can easily be reused in a new car whereas a new alternator cannot, clearly it seems better to buy a new amplifier instead of a new alternator and use a 4 ohm sub, right? I am assuming that you cannot buy both a new amplifier and new alternator, and that they cost about the same. Is my logic correct?
If it is, why do people upgrade to expensive alternators when they could spend the money on an amplifier instead, and run higher resistance speakers, all on the stock alternator, with all the advantages I mentioned, and the same power output either way? Did I miss something?
jeffchilcott
Platinum - Posts: 2,483
Posted: February 28, 2007 at 1:07 AM / IP Logged
No, in the long run it will always take power to make power, no matter what the resistance of the woofer is.
To make a good UNCLIPPED 1000 watts of power you will generally need 75-100 amps of current.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
cim2phat4u
Member - Posts: 22
Posted: February 28, 2007 at 1:10 AM / IP Logged
Sorry I meant to say P = I*V = I*I*R
cim2phat4u
Member - Posts: 22
Posted: February 28, 2007 at 1:21 AM / IP Logged
From the way I see it, according to the formula P = I*I*R, you can increase the power two ways. Either increase the current, or increase resistance. If you increase current, you will need to upgrade the alternator. If you increase current, you will need to upgrade the amplifier. Either way, this gives you the same power, and I don't see how using one method would produce clipping compared to the other. Am I wrong?
Most people go to upgrade their alternator so they can run their subs at 2 or even 1 ohm, thinking it is increased performance. However, my argument is that it is better to upgrade the amplifier, run the subs at high resistance like 8 ohm, and you can get the same power from your stock alternator due to decreased current, plus you have the benefits of better sound quality and a reusable amplifier. Somehow, my argument seems strange, but I can't figure out how it's wrong.
cim2phat4u
Member - Posts: 22
Posted: February 28, 2007 at 1:23 AM / IP Logged
Should read "if you increase resistance, you will need to upgrade the amplifier." God I keep making typoes today SORRY!
haemphyst
Posted: February 28, 2007 at 8:52 AM / IP Logged
OK... You are very confused, it seems...
If you increase the resistance say, from 2 ohms to 4 ohms, you have to increase the VOLTAGE to overcome the additional resistance to drive the current THROUGH the resistance to make power. If all you do is increase the resistance, you cannot get the same power through it, as the current will drop, because the voltage was not increased to overcome the increase in resistance. It all goes hand in hand. Plug the numbers into the formulae, and you'll see.
Amplifiers are current devices, they regulate the current output to try to maintain a given VOLTAGE on their output rails. This is why power ratings increase when the load increases (this means lowering the impedance), the voltage remains the same, but when you halve the impedance, the amp will try to double the CURRENT to maintain the same voltage across the terminals. Twice the current with the same voltage, means twice the power. It all plugs in together.
