remote start wiring 2007 solstice
racer778
Posted: March 05, 2007 at 7:34 AM / IP Logged
hello, new to the forum can I get the wiring information for a 2007 pontiac solstice.  I am planning on installing a remote start.  also would like recommendations on brand, transponder etc.
thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: March 05, 2007 at 11:04 AM / IP Logged
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS RED / black On C3 connector at BCM   +
 The BCM is located directly below the glovebox. The connector layout is as follows: C1 (gray 72-pin), C2 (gray 72-pin), C3 (red 40-pin) and C4 (gray 68-pin)
 IGNITION Yellow Ignition switch or C4 connector at BCM   +
 ACCESSORY Brown Ignition switch or C4 connector at BCM   +
 STARTER SEE NOTES
 No connection to the start wire is required. With proper Transponder bypass, the vehicle will crank automatically.
 TACH SIGNAL Use a fuel injector
 FUEL INJECTOR Opposite from Pink/black wire At any injector on engine   AC
 LOCK Gray On C3 connector at BCM   REV POL
 These are the motor wires and you must wire it up as reverse polarity. The BCM is located directly below the glovebox. The connector layout is as follows: C1 (gray 72-pin), C2 (gray 72-pin), C3 (red 40-pin) and C4 (gray 68-pin)
 UNLOCK Tan On C3 connector at BCM   REV POL
 DOORPIN SEE NOTES
 GRAY/BLACK (driver's door) and TAN/WHITE (pass. door) Both are neg (-)and found at the C1 connector on the BCM. The BCM is located directly below the glovebox. The connector layout is as follows: C1 (gray 72-pin), C2 (gray 72-pin), C3 (red 40-pin) and C4 (gray 68-pin)
 TRUNK PIN ORANGE / black On C1 connector at BCM   -
 TRUNK RELEASE Tan At swicth or C2 connector on BCM   -
 FACTORY ARM Through OEM remote only
 FACTORY DISARM Through OEM remote only
 BRAKESWITCH Lt.blue On C1 connector at BCM   +
 PARKLIGHTS Brown In driver's kickpanel or C3 connector at BCM   +
 HAND BRAKE Lt.blue On C1 connector at BCM   -
 HORN Tan At steering column or C2 on BCM   -
racer778
Posted: March 05, 2007 at 11:11 AM / IP Logged
thanks
