camry 07 immobilizer, how to disable?
legenux
Copper - Posts: 92
Posted: March 09, 2007 at 3:39 PM / IP Logged
I was told camry 07 has immobilizer, and will not let the starter engage when its on. How can I shut down the < face=OfficinaSans-Book >immobilizer system for remote starting? Thanks.
rudydapimp
Copper - Posts: 390
Posted: March 09, 2007 at 4:51 PM / IP Logged
get the XK05 from bypasskits.com.  reliable bypass.
legenux
Copper - Posts: 92
Posted: March 09, 2007 at 5:14 PM / IP Logged
I have the 556U. I guess I was asking besides the 556U, do I have to tap into the blue sense wire with ground to disable alarm? Thanks.
peterubers
Silver - Posts: 706
Posted: March 10, 2007 at 9:51 AM / IP Logged
supply the keysense wire with a NEG(-) or POS(+) (read the wiring diagram to determine what polarity the keysense wire needs .. i cannot recall) that is triggered by your Ground While Running (-) wire off the Remote start brain -- also, diode isolate your GWR(-) connection to your 556U if you use the same GWR wire to trigger both things.
The search function is your friend.
Mike M2
Platinum - Posts: 2,652
Posted: March 10, 2007 at 11:15 AM / IP Logged
The keysense wire is blue at the column and needs to see a ground whenever the Rs is on.
Mike M2
Tech Manager
CS Dealer Services
soultinter
Copper - Posts: 170
Posted: March 10, 2007 at 11:36 AM / IP Logged
that is only to disarm the factory alarm, not the immobilizer system (which is the chip in the key) the 556u will do that.
Mike M2
Posted: March 10, 2007 at 1:21 PM / IP Logged
That's pretty much what he asked....
Mike M2
Tech Manager
CS Dealer Services
KarTuneMan
Platinum - Posts: 7,056
Posted: March 10, 2007 at 6:50 PM / IP Logged
Remember...you need to trigger BOTH, with ground while running (remote started). If you use ONE GWR, diode isolate the 2 "features" keysence, and transponder bypass.
legenux
Copper - Posts: 92
Posted: March 10, 2007 at 8:48 PM / IP Logged
Thank you. I will try this tomorrow.
