vats bypass
vger7
Member - Posts: 9
Posted: March 11, 2007 at 4:11 PM / IP Logged
i am trying to install a vats bypass module in a 2001 corvette, and i need to know the location and color(s) of the wires coming from the interrogator decoder module. can someone please help?
thanks,
vger7
Platinum - Posts: 12,488
Posted: March 11, 2007 at 5:49 PM / IP Logged
The VATS wire will be in an ORANGE sleeve. The VATS wires are both WHITE and one is GROUND and the other will change voltage when you turn the ignition to the ON position. It will register only about 5 volts though.
vger7
Member - Posts: 9
Posted: March 11, 2007 at 7:06 PM / IP Logged
Thanks Jeff.
vger7
