1995 Plymouth Neon wiring diagram
joseph0608
Member - Posts: 14
Posted: February 06, 2003 at 7:18 PM / IP Logged
A couple of months ago I installed an alarm on my vehicle and the wiring diagram I got from this site helped me out a whole lot. I just acquired a 1995 Plymouth Neon and planning to install door actuators and an alarm again. I'd really appreciate it if you guys can help me out again with the wiring diagram. Thanks so much.
Bnluis
Silver - Posts: 578
Posted: February 06, 2003 at 8:00 PM / IP Logged
1995 Neon
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & pink/black    |+  |ignition harness *1         |
|          STARTER|yellow              |+  |ignition harness *1         |
|         IGNITION|dk. blue            |+  |ignition harness *1         |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness *1         |
|       POWER LOCK|ORANGE / purple       |5wi|taped harness from driv door|
|     POWER UNLOCK|pink/purple         |5wi|taped harness from driv door|
|       LOCK MOTOR|ORANGE / black        |   |drivers kick                |
|     UNLOCK MOTOR|pnk/wht or pnk/blk  |   |drivers kick                |
|    DISARM DEFEAT|pink/black          |   |passenger kick              |
| PARKING LIGHTS +|BLACK / YELLOW        |   |at headlight switch         |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|lt. green           |+  |at headlight switch         |
|     DOOR TRIGGER|yellow              |-  |behind headlight swtch      |
|  TRUNK/HATCH PIN|gray/black          |-  |at light in trunk           |
|       TACHOMETER|tan/blu or blk/gry  |   |top motor 3 pin plug        |
|       BRAKE WIRE|WHITE/ gold dots     |+  |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|grn/yel, RED / yel    |+  |steering column *2          |
|  LF WINDOW UP/DN|                    |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 SRS airbag wires are not enclosed in sheath at the steering column. They are a twisted pair run with rest of ignition harness. Be careful not to cut or probe these wires.  *2 Combine with diodes to get all speeds.
Make sure the test wires whenever possible. also here is a diagram to   add aftermarket actuators.1995 Plymouth Neon wiring diagram -- posted image.
Luis
Sound Waves
joseph0608
Member - Posts: 14
Posted: February 07, 2003 at 7:44 PM / IP Logged
Thanks, appreciate it a lot.
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
