1995 jeep cherokee cm3000 remote start
bpres
Posted: March 11, 2007 at 10:53 PM / IP Logged
I'm installing a remote starter compustar cm3000M in a 95 jeep cherokee, manual transmission.
The system has a reservation mode that requires a connection to a wire
that shows negative when the parking brake is engaged. Any ideas what
color that wire would be, where it would be located, or a suitable
negative wire workaround? All else is good with the install.
Thanks-
bpres
custom audio ny
Copper - Posts: 176
Posted: March 11, 2007 at 11:23 PM / IP Logged
Not meaning to sound sarcastic but that wire is located at the parking brake. You will see a wire coming off the switch at the brake..that wire will show negative when engaged. Since this is a manual tranmission vehicle you really should not "work around" it... safety and liability comes first.
Sorry I don't know the color but it will be the only wire at the parking brake so it's really a no brainer.
If you need any more assistance just ask.
Custom Audio
Lynbrook NY
ASE/MECP master certified
bpres
Posted: March 12, 2007 at 7:51 AM / IP Logged
Wow. I feel not bright.
That certainly makes it easy.
Thanks.
bpres
