i fast 06 kia rio?
installerman23
Copper - Posts: 53
Posted: March 19, 2007 at 3:12 PM / IP Logged
Does anybody have a wiring diagram for a 06 Kia Rio?I tried directechs and all they had was for an 05 and the wires aren't matching up.Any help would be greatly appreciated!!!
KarTuneMan
Platinum - Posts: 7,056
Posted: March 19, 2007 at 10:05 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Green or Blue Ignition switch harness   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Orange Ignition switch harness   +
 STARTER White Ignition switch harness   +
 KEY SENSE Red Ignition switch harness   +
 TACH SIGNAL Green In blue plug on left of fusebox under dash   AC
 Can also use the wire that is not BLACK/ white at any of the coils on the engine.
 FUEL INJECTOR Oppossite from Gray wire At any injector on engine   AC
 LOCK Blue On Green connector in driver's kickpanel   -
 UNLOCK Yellow/black On Green connector in driver's kickpanel   -
 DOORPIN Green Driver's kickpanel in harness to rear   -
 HOODPIN Brown In blue plug on left of fusebox under dash   -
 TRUNK PIN GREEN/ orange Driver's kickpanel in harness to rear   -
 FACTORY ARM Yellow/orange On Green connector in driver's kickpanel   -
 FACTORY DISARM WHITE/ black On Green connector in driver's kickpanel   -
 BRAKESWITCH RED / orange On gray 18-pin plug on the fusepanel   +
 PARKLIGHTS GREEN/ black On brown 14-pin plug on the fusepanel   +
 PARKLIGHTS (-) Red At light switch harness   -
 HAND BRAKE GREEN/ orange On brown 14-pin plug on the fusepanel   -
 HORN Blue In white plug at steering column   -
 CLUTCH SWITCH BLACK/ orange At switch on clutch pedal bracket   Type 2
 REVERSE LIGHTS WHITE/ black On brown 14-pin plug on the fusepanel   +
 VSS WIRE RED / orange In diagnostic plug below driver's dash   AC
