cadence wild beast 12 or treo tsx10.44
banginloud
Member - Posts: 18
Posted: March 29, 2007 at 7:06 PM / IP Logged
Trying to decide between 2 Cadence WB124's or 2 Treo Engineering TSX10.44's.I know both are good but i am kinda leaning towards the cadence wild beast.The cadence seem to have some amazing specs.The treo's on the other hand come in a custom built box by treo themselves.I guess either way the sound would be pretty brutal.
Cadence:
SPECIFICATIONS:
  • Voice Coil: Huge 3" Four-Layer
  • Impedance: 4 ohm Single Coil
  • Power Handling: 700 Watts RMS / 1400 Watts PEAK
  • Magnet Size: Double Stack 150oz. Structure
  • Frequency Response: 20Hz - 500Hz
  • SPL @ 1w/1m: 95dB
  • Mounting Depth: 7"
FEATURES:
  • Composite Kevlar Orange Cone.
  • Oversize Butyl Rubber Surround.
  • Light-UP Magnet Motor Structure.
  • Vented Heat Pump Basket Design.
  • Four Layer Kapton High Power Voice Coil.
  • One Piece Extended Pole Technology with Super Extended Motor Structure.
  • Tinsel Lead Woven into Progressive Linear Conex Spider.
The massive motor structure combines double magnets, sandwiched between two super chrome plates, and surrounded by a light-up aluminum helix. The flat progressive Nomex spider with integral tinsel provides precise coil alignment and critical cone motion control under high power applications.The cast aluminum basket is powder coated in a deep orange color and the edges diamond cut to a glistening finish. Gold 5-way banana binding posts are standard. CCT, Composite Cone Technology, combines a layer of Pulp & Nomex to a woven Kevlar substrate for added rigidity & dampening for the absolute deepest bass. The long throw design of the Wild Beast is well matched with the massive Butyl rubber surround which controls linearity. Optimized for vented SPL enclosures.
TREO:
HOTBOX ENCLOSURE FEATURES:
-         TWO TSX10.44
-         TREOHYDE POLYMER-BASED COATING AND FEATURE ALUMINUM MOUNTING BAFFLES
-         5-WAY BINDING POSTS AND ENGRAVED LOGOS
-         CONFIGURABLE TO ONE OR FOUR OHM OPERATION WITHOUT REWIRING
TSX12.44 FEATURES:
From Treo’s website:
“Take all the virtues of the Treo Series subwoofers and top it all off with larger dual voice coils, double stack magnets, and insane power handling, and you end up with a Treo Series Extreme subwoofer.  It's what happens when Darwin starts designing speakers. The TREO TSX now features a silver powder-coated basket, a debossed TREO logo on the magnet boot, and a new wrap-around gasket with an aluminum plate with the TREO Engineering logo. Power handling has increased over thirty percent; the ten and twelve inch models now handle 400 watts RMS and the fifteen inch models now handle up to 500 watts RMS!”
Features:
- Precision CNC-machined low-carbon steel motor structure.
- Powerful and durable double-stacked strontium ferrite magnets with a protective rubber magnet boot
- Durable and attractive black oxide-treated motor structure
- High-flow large diameter pole vent
- High excursion motor structure and suspension design
- Wide three-layer UV-treated foam surround
- Resin-impregnated poly-cotton damper for increased cone control
- Integrated tinsel leads for increased reliability and enhanced sound quality at high excursion
- Mica-impregnated polypropylene cone and dustcap
- Cold-rolled stamped steel basket with rolled edges
- 2.5 inch high-temperature Aluminum voice coils
- Upgraded power handling to 400 Watts - Dual 4 Ohm voice coils for increased installation flexibility
- Optimized for small to medium sealed, vented, and bandpass enclosures
- Built by hand in the United States from domestic and imported components
banginloud
Member - Posts: 18
Posted: March 29, 2007 at 7:08 PM / IP Logged
Wow copy and paste did not work like expected.Anyways just want opinions between the two.
jeffchilcott
Platinum - Posts: 2,483
Posted: March 29, 2007 at 7:48 PM / IP Logged
Not really a big fan of cadence...kinda cheap stuff in my oponion...Im a a fan all all thge lines of treo though
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
