2001 Grand Marquis, 2nd Accessory Tip
zargon
Copper - Posts: 186
Posted: February 08, 2003 at 4:41 PM / IP Logged
today learned that a grand marquis must have it's second accessory wire fired up so that the alternator will turn on, i can't believe that i just figured it out now! I've done quite a vew of them with my only problem being that tach and the ignition coil would not work for tach because of what dei said was a low voltage problemwith this car, no wonder when the alternator is not on, we have done around sixty of these and this is the first one with a problem of running the battery down, learn something new every day,hope this helps someone!!! see ya!!!!!
zargon ruler of estranorth
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
