hid in house testing
menappi
Member - Posts: 25
Posted: April 02, 2007 at 7:13 PM / IP Logged
I need to figure out a way to test hid ballasts and bulbs in house without the use of a car battery. So i'm assuming there should be a way using some device that I can plug into a typical wall outlet, or a combination of some easily obtainable parts that I can put together to do this. If anyone can help me out I would greatly appreciate it. I need to test a large amount of HID's and installing them into cars would take too much time.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 03, 2007 at 9:30 AM / IP Logged
Get yourself a motorcycle battery, and a slow charger. An inverter might not be the best way to do what you want to do, (no battery) The ballasts, and the bulbs, need to warm up. The initial start up need, might exceed the outputs of a cheep inverter.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
