need to hook up factory tv on excursion
coopdawg
Member - Posts: 6
Posted: April 03, 2007 at 2:39 PM / IP Logged
I have an avic-d3 and I would like to hook up my factory rear tv on my 2002 Ford Excursion so that the tv in the back displays what I am watching on my D3.
My factory dvd player has an input so I can hook into it and drive it from there. The problem I have is the factory tv and dvd player will not light up without the factory cd player installed. Does anyone know what I need to do to power these two up so I can send my d3 signal back to it?
adglascoe
Member - Posts: 9
Posted: April 03, 2007 at 2:46 PM / IP Logged
you have to hook-up the green with black from the back of the radio to 12-volt ing. and that will turn on the factory tv/dvd.
adglascoe
coopdawg
Member - Posts: 6
Posted: April 03, 2007 at 3:17 PM / IP Logged
Thanks for the fast reply!  Would you recommend hooking up the hot wire that powers the rado to it?
adglascoe
Member - Posts: 9
Posted: April 03, 2007 at 3:20 PM / IP Logged
yes you can do that just hook it to the 12 volt ing.. you can just make a jumper wire with a fuse and hook it up behind the radio
adglascoe
coopdawg
Member - Posts: 6
Posted: April 04, 2007 at 4:21 PM / IP Logged
For some reason, when I hook that wire up, it will power the tv up, but for an unspecified time.  It may turn on for 20 seconds, it may stay on for 4 mintutes.  Any ideas?
adglascoe
Member - Posts: 9
Posted: April 04, 2007 at 4:41 PM / IP Logged
I'll look in to it
adglascoe
adglascoe
Member - Posts: 9
Posted: April 04, 2007 at 4:43 PM / IP Logged
also do you have a dvd in the unit or have something in the aux. input when you power it up
adglascoe
coopdawg
Member - Posts: 6
Posted: April 05, 2007 at 9:27 AM / IP Logged
no, I didnt have a dvd in when I hooked it up.
supersix4
Copper - Posts: 71
Posted: April 05, 2007 at 11:27 AM / IP Logged
Put a DVD in the Ford player .... it should stay on as long as the DVD is playing .... provided the battery isn't weak or dead.
coopdawg
Member - Posts: 6
Posted: April 05, 2007 at 11:40 AM / IP Logged
but if it's playing in the dvd player,  witll I be able to switch over to auxillary and let my front deck drive it?
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
