05 dakota vss?
1456wires
Member - Posts: 16
Posted: April 04, 2007 at 7:37 PM / IP Logged
Just installed the new JVC KD-NX5000 and it requires a VSS wire. After checking the Rostra site and testing every wire in the green plug I have come to the conclusion that I have to use a can-bus interface. We had a Soundgate canpulse2 in and we installed it. This does give us a signal but now the nav unit believes the truck is constantly going 35 mph. I will call soundgate in the morning and it may be a simple fix. But if anyone has some input that would be great.
spookiestylez
Silver - Posts: 531
Posted: April 04, 2007 at 7:56 PM / IP Logged
This bit of info comes from Audiovox tech services.
Speed Sense WHITE/ ORANGE (AC) PCM CONNECTOR 4, PIN 26
PCM IS LOCATED ON RIGHT INNER FENDER UNDER HOOD
Hope this helps ya a little bit!
sS
rtfm
1456wires
Member - Posts: 16
Posted: April 04, 2007 at 9:02 PM / IP Logged
I know I haven't tested that wire yet. I will test first thing in the morning
Thankx
spookiestylez
Silver - Posts: 531
Posted: April 04, 2007 at 9:05 PM / IP Logged
Welcome, hope you get it working before lunchtime and millertime
rtfm
1456wires
Member - Posts: 16
Posted: April 10, 2007 at 10:55 PM / IP Logged
After much advice from everyone. Thank you!
Peripherial has a piece that gets VSS,ign,reverse and dimmer. It does not list it as working on the Dakota. It does work and I wish I would have tried it sooner
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
