false triggering, autopage alarm, 99 regal
bigwilllo17
Posted: April 07, 2007 at 1:52 PM / IP Logged
hi i have a 99 buick regal and i had an autpage alarm installed, i took it to a shope they did everything. the same day it start fals triggering, i took it back they say theres nothin wrong with it. it sometimes stop false triggering for a couple of days then out of nowhere it happens. i checked it out myself and the place that installed it ran my hood and trunk sensor to another wire. thers no pin in the trunk or under the hood i never saw that befor. also i looked unerd i have a gem hangin and nothing goin to it. i have the autopage rs-725 and its reading that either the trunk or hood is open and its not. whats goin on
Twelvoltz
Platinum - Posts: 2,384
Posted: April 07, 2007 at 1:57 PM / IP Logged
If you had this professionally installed, the shop should be taking a look at it. Explain to them everything you posted here and they should fix the problem for you. This should be covered under their warranty and should not cost you any more money. If you go messing around with whatever they put in, they can void their warranty on the unit and you would be stuck.
bigwilllo17
Posted: April 07, 2007 at 2:00 PM / IP Logged
i did that they couldnt find anything wrong wit it if i cant fix it myself im just goin to have to take it somewhere else, and they will pay for it
KarTuneMan
Platinum - Posts: 7,056
Posted: April 07, 2007 at 5:09 PM / IP Logged
Keep returning to the dealer until you get it fixed.......if they cannot fix it, DEMAND a refund and have the unit removed. YOU are not getting what you paid for.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
