2002 escalade ext 6.0 navigation
98dodge
Member - Posts: 31
Posted: April 13, 2007 at 1:44 PM / IP Logged
Hi,
I've run a couple searches, and wanted to be sure, I'm looking for the VSS wire, and the Reverse Wire leads.... Some have said at the PCM some have said behind the radio, does anyone have a exact location on these leads for this vehicle? Thanks in advance...
2002 Escalade EXT 6.0 W/ BOSE SPEAKERS
Bnluis
Silver - Posts: 578
Posted: April 13, 2007 at 1:48 PM / IP Logged
GREEN/ white behind the radio at radio harhess or can also be found behind cluster next to a White wire( Tach)
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
98dodge
Member - Posts: 31
Posted: April 13, 2007 at 2:52 PM / IP Logged
Thanks for the info, Any idea's on the reverse wire lead?
Bnluis
Silver - Posts: 578
Posted: April 13, 2007 at 8:52 PM / IP Logged
you can find it at the rear lights, Ii I remmember correctlly is Light Green Yo can also find it at the BCM below steering column.
Luis
Sound Waves
