need speaker selection
grey1998
Posted: April 14, 2007 at 8:25 PM / IP Logged
I own a 98 F150 regular cab.  I want to install new speakers but really have no clue where to begin. I do know I want a pair of tweeters, a mid/mid bass, with an eight inch sub. I am not looking for a lot of thump but a well rounded sound. Any suggestions would be greatly appreciated. One question I have concerns sealed mid range speakers I have seen. Will a sealed mid-range speaker work well in auto applications?
My head unit is a new Pioneer. 50 watts per channel.
Grey1998
Alpine Guy
Platinum - Posts: 2,478
Posted: April 14, 2007 at 10:18 PM / IP Logged
I believe that truck has 5x7" speakers in the doors factory. In the past I have taken advantage of the extra space and fabricated little enclosures for 6.5" speakers out of fiberglass and mounted tweeters on the door panel itself. It sounded very very good, keep in mind that kind of install isn't cheap. You may want to opt for getting plates mounted to fill the hole of the 5x7" speaker and mount a 6.5" mid in there and a tweeter on the door. No one will be able to recommend which speakers will be best for you so stop by your local car audio shops and listen to the component systems. You most likely will need to run the component speakers off of a small amp to get them sounding right, the amp in the cd player just wont cut it.
Now for the sub's, check out an amazing sub made by Sound Splinter Audio at www.soundsplinter.com it is the RL-i8 model.
rudydapimp
Copper - Posts: 390
Posted: April 15, 2007 at 9:41 AM / IP Logged
I believe that the speakers are 6x8's all the way around.
DYohn
Platinum - Posts: 10,741
Posted: April 15, 2007 at 10:30 AM / IP Logged
6X8 = 5X7.  Same form factor.
I say GO SHOPPING.  Grab your favorite CD and visit as many car audio shops as you can.  Listen to a music track you know and like and choose the speakers you like the most and can afford.
grey1998
Posted: April 15, 2007 at 2:54 PM / IP Logged
Thanks for the suggestions. I have such a difficult time knowing what to do for a set up.  I see I will have to have an amp to power the system. I guess I will go with some component speakers with a small sub.  Once again, thanks!
Grey1998
zhalverson
Copper - Posts: 180
Posted: April 17, 2007 at 4:44 PM / IP Logged
2nd vote for the soundsplinter rli-8".  Heard nothing but good things and Mike @ soundsplinter is a great guy to work with.  Check out this link to see them in action: http://www.teamtoxicbass.com/~pete/car_audio/project_hellboy/index.html
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
