cm3300 compustar
shady_101
Posted: April 21, 2007 at 4:54 PM / IP Logged
I have just recently bought a compustar 3300 alarm/starter. I just need to know what wire i would need to hook up for just the alarm....i hooked it up to the best of my knowledge the sensor comes on but there's no chirp or nothing....here is the diagram for the alarm/starter......could you please post what i need to wire up for just the alarm. I dont want nothing to do with the remote start.
http://staub.ca/tech/Manuals/Firstech/CM3300_wiring_manual.pdf
y2k-gt
enice
Silver - Posts: 857
Posted: April 21, 2007 at 6:10 PM / IP Logged
Connector 1---Brown is siren, GREEN / WHITE is the parking lights(POSITIVE), red is 12v constant, black is ground.
Connector 2---GREEN / WHITE is the parking light(NEGATIVE),white is your car horn(-), violet wire goes to kill switch(pin 85 or 86 on relay), green is ign,violet is the dome supervision(-), orange goes to factory alarm rearm, ORANGE / white is factory disarm on the factory alarm,
Connector 3--Gray/black is for your hood pin, violet/black is usually trunk trigger, red.white is (-) door trigger if your car has negavite triggers, red is (+) door trigger if your car has positive triggers.
Connector 4---violet/white is a trunk release  which is (-), blue wire is a (+) for door lock, blue black is a (-) for door unlock***note that it double pulses as a (-) unlock output when using blue wire and double pulses as a (+)unlock output.
FOR violet wire in connector 2 you can use pin 86 for ign, cut starter and connect one wire to 87a and the other to 30.  Hope that helps
enice
Silver - Posts: 857
Posted: April 21, 2007 at 6:11 PM / IP Logged
for connector 4 the (+) double pulse is for blue/black wire
