need amp in 2000 explorer
jonafer
Member - Posts: 19
Posted: April 26, 2007 at 10:50 AM / IP Logged
I want to put a amp in a 2000 explorer. I will be using my factory head unit. I want to run rca cables from the head unit to the amp but the head unit has no hook up for rca cables.  I know the amp turn on is blue, I just want to understand how to use the rca cable with the factory head unit. Thanks a bunch.
azaudio41
Member - Posts: 11
Posted: April 26, 2007 at 11:02 AM / IP Logged
your gonna need whats called a loc ( line output converter) it will convert the speaker signal to rca's.  also your ignition/ turn on wire should be BLACK/ pink behind the radio
jonafer
Member - Posts: 19
Posted: April 26, 2007 at 11:31 AM / IP Logged
how does a loc work. The vehicle wiring on this site says the remote turn on is blue. Thank's
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
