2003 tahoe pioneer navigation
jbaird
Posted: April 27, 2007 at 8:49 AM / IP Logged
I am going to be installing a Pioneer AVIC-Z1 in my 2003 Tahoe. From what I understand, the Tahoe does not have an illumination wire in the factory harness. Does anyone have an idea of where I can easily get a 12V source when the headlights are on that will allow my Z1 to properly dim/go into night mode? I have also heard that I can find a VSS wire piggyback in the factory harness (green wire).. can anyone confirm this? Also, any other non-standard wires/locations I should be aware of? Thanks!
KarTuneMan
Platinum - Posts: 7,056
Posted: April 27, 2007 at 4:56 PM / IP Logged
+12V DC Battery(Constant)Orange  Radio 15 amp Fuse block at left side of engine compartment
Ground Black
Dimmer BROWN / white
Steering Wheel Control Wire Dark blue Also light green
extreme1
Silver - Posts: 1,070
Posted: April 28, 2007 at 12:02 AM / IP Logged
Dimmer, BROWN / white @ heater control's
VSS, dk.GREEN / WHITE @instrument cluster
Reverse, lt. green at junction box, drivers kick
Shaughn Murley
Visions Electronics
Red Deer, Alberta
jbaird
Posted: April 30, 2007 at 10:32 AM / IP Logged
Thanks!
jbaird
Posted: May 07, 2007 at 7:46 PM / IP Logged
I can't seem to locate the dimmer/illum wire. Which harness is it in?
extreme1
Posted: May 08, 2007 at 8:21 AM / IP Logged
I have always grabbed it at the heater controls harness. it is BROWN / white, you can also grab BROWN / white at the light switch
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
