Pos to ground via relay?
Spacecwboy
Member - Posts: 10
Posted: February 10, 2003 at 7:50 PM / IP Logged
Is there a way to change the output from pos to neg via a relay?  I am installing an add on remote start and I cant find anything to use as my ground trigger on my alarm that is a neg output.  So can I go from a pos output (like on my door unlock) to a neg output throught the relay?
Bnluis
Silver - Posts: 578
Posted: February 10, 2003 at 8:23 PM / IP Logged
Yes. connect pin 86 and 87 to ground, pin 85 fom your positive trigger and pin 30 will be your ground trigger.
Pos to ground via relay? -- posted image.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
zargon
Copper - Posts: 186
Posted: February 10, 2003 at 8:30 PM / IP Logged
question is what are you trying to trigger, if you are trying to activate a add on remote start with your alarm there should be a negitive trigger out, let me know what you a doing.
zargon ruler of estranorth
mobiletoys2002
Gold - Posts: 1,050
Posted: February 21, 2003 at 9:51 PM / IP Logged
note on relays always try to use 85 for ground and pin 86 for positive.Even thiough both ways will work newer relays have a diode across the coil and 85 to ground and 86 to positive would be the correwct way to wire any relay especially when dealing with troubleshooting factory relays. Its just easier and more trouble free in the long run .AGAIN EITHER WAY WILL WORK/
