viper 5900 multiple sensors
prodigalson
Posted: May 02, 2007 at 2:51 PM / IP Logged
Hi,
I just had a Viper 5900 installed. From reading the user manual it seams possible to have 2 sensors. Currently there is only a proximity (508d) attached. It sets off the pager as sensor 2.  The pager has an icon for sensor 1 and sensor 2.  Is it possible to have them hook up the proximity as sensor 2 and the shock as sensor 1. If so how would they go about this? My shop had no clue what I was talking about.
creed2k
Copper - Posts: 99
Posted: May 02, 2007 at 5:34 PM / IP Logged
hmmm, i dont know about that, i believe the shock sensor reports 2 for heavy impacts and 1 for light impacts... i could be wrong though...
prodigalson
Posted: May 02, 2007 at 6:13 PM / IP Logged
Do light impacts usually warn away? The pager says warn away plus the sensor that triggered it.
creed2k
Copper - Posts: 99
Posted: May 03, 2007 at 1:19 PM / IP Logged
yeah light impacts warn away, but are u saying the remote displays the warn away? cause i dont believe it does...
prodigalson
Posted: May 03, 2007 at 8:12 PM / IP Logged
Yes. I wish I had the pic thats in the manual to post on here. On the left hand side theres a little speaker picture. Above this is the word WARN and below is ALARM. Warn away lights up WARN and a full trigger lights up ALARM.
I just found my answer. On page 13 of the manual it says Sensor 1 is displayed if the Dual-Stage shock sensor has been triggered as a full triggered or warn away sequence. Sensor 2 is for an additional dual stage sensor has been triggered.
So whats the propper way to wire this on theVIPER 5900?
enice
Silver - Posts: 857
Posted: May 03, 2007 at 9:54 PM / IP Logged
There's no real proper way, it plugs right in.  No other connection required.  Other then there is another wire coming off the harness.  If im not mistaken it is a green wire thats loose
prodigalson
Posted: May 03, 2007 at 11:04 PM / IP Logged
I'm not understanding. The 5900 brain has 1 plug input for the shock sensor? If the 504d is plugged in, how does the 508d get plugged in?
enice
Silver - Posts: 857
Posted: May 03, 2007 at 11:41 PM / IP Logged
look at this post and look for the 1st reponse(not original post).  it shows the proper way of connecting your 508d...https://www.the12volt.com/installbay/forum_posts.asp?tid=82309&KW=508d
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
