spst momentary switch constant on/off
audioduck
Member - Posts: 25
Posted: May 05, 2007 at 1:02 PM / IP Logged
I'm looking for a way to switch 12v constant on and off and with a SPST momentary swtich to switch a 12V accessory on and off..   If there's a product out there that will do this for a reasonable price that would be fine as I'd just as soon not have to build a circuit.
I've done a fair amount of Googling and can't find what I'm looking for but I know it must exist somewhere.
TIA
Platinum - Posts: 13,726
Posted: May 05, 2007 at 6:04 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=89844&KW=latching+relay
audioduck
Member - Posts: 25
Posted: May 05, 2007 at 9:24 PM / IP Logged
Would it be feasible to use a premade PCB latching relay to power a Bosch-type relay?.  I found one at Mouser that is only $5, is 12V and has a 2amp capacity which should easily drive a Bosch 20A relay.  This would save me both time and the hassle of putting together a the more complex latching circuit.
Here's the one I'm looking at:
http://www.mouser.com/search/ProductDetail.aspx?R=IM46GRvirtualkey65510000virtualkey655-IM46GR
