viper 791xv add remote
mikmak
Member - Posts: 6
Posted: May 09, 2007 at 8:46 PM / IP Logged
Can I add A remote to my system and what are the procedures, if possible?
captainzab
Silver - Posts: 606
Posted: May 09, 2007 at 8:57 PM / IP Logged
Yes
Search Result
open drivers door, press the push button valet/programming switch one time, then press and hold it in... the LED should flash once.. press button one on the new remote, then press it a second time... the siren should chirp once to acknowledge that it's programmed....
you NEED the programming push switch in order to learn a new remote...
Note: You Always Dont Get What You Pay For.
mikmak
Member - Posts: 6
Posted: May 09, 2007 at 9:23 PM / IP Logged
My second remote is a companion remote. Tried the programming above and nothing. Will this remote still work? It looks different than my primary controller.
