2007 avalanche vss
nah_zee
Member - Posts: 12
Posted: May 16, 2007 at 12:02 AM / IP Logged
I need to find the vss wire in a 2007 chevy avalanche that has bose and onstar so I can put in the pioneer avic d1
Mike M2
Platinum - Posts: 2,652
Posted: May 17, 2007 at 6:50 PM / IP Logged
Under the hood, the big fuse box on the drivers side. There's two harnesses with plugs at the bottom edge closest to the motor. The plug nearest the firewall, GREEN / WHITE wire....
Mike M2
Tech Manager
CS Dealer Services
ectf2003
Posted: June 02, 2007 at 8:34 PM / IP Logged
Mike, I have hear a few variations of this.  1.) VSS wire comes from the ECM drivers side close to the radiator - 72 pin connector - yellow and black wire at PIn 57.    2 INstallers I spoke to told be the yellow and black wire, and I have seem some internet posts saying green and white.  I have a 2007 Avalanche.
Your post which says the green and white one cokming from the fuse box.   I am confused - will both work or is one wrong?
Thanks is advance for you help.
My turn by turn guidance in the OEM nav that I installed doesnt start - i am assuming that it may be because of the vss wire.  It does follow me on the map.
Pete
nah_zee
Member - Posts: 12
Posted: June 03, 2007 at 12:41 PM / IP Logged
the green white wire is correct, I tried both because I also had both answers, but mike is right, go to the GREEN / WHITE wire at the fuse box
ectf2003
Posted: June 03, 2007 at 7:20 PM / IP Logged
That would explain why the connection to the yellow and white wire was not working.   Since your post, I have changed to the green and white wire from the fuse box.  I really appreciate the information.  Thanks!!!
Pete
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
