speakers making noise, converter
datroboy510
Member - Posts: 6
Posted: May 27, 2007 at 1:00 PM / IP Logged
after i installed my output converter to the back speakers...everytime i turn it up and when the bass kicks, it makes a "CLICK" sound..only when the bass kicks..?????
DYohn
Platinum - Posts: 10,741
Posted: May 27, 2007 at 3:22 PM / IP Logged
Sounds like you are over-driving your speakers.  Either too much power or they need a high-pass filter.  Or both.
haemphyst
Platinum - Posts: 5,059
Posted: May 27, 2007 at 3:44 PM / IP Logged
If you do use a hi-pass filter (i.e. a "bass-blocker") be sure you install it AFTER the connection point where you tapped the wires for your LOC. If you tapped the LOC behind the deck, you're pretty safe, you can then put the bass-blockers anywhere in the line, but right at the speaker is generally best. I just wanted you to be aware of that.
Platinum - Posts: 13,726
Posted: May 27, 2007 at 7:44 PM / IP Logged
     Does your vehicle have a trunk? are your rear speakers mounted in the rear deck?
jmelton86
Gold - Posts: 1,228
Posted: May 28, 2007 at 7:04 PM / IP Logged
Wouldn't FMODS be better? This way the amp is only amplifying bass freq's, saving power. Right?
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=266-250
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
