2004 Nissan Almera Alarm/Remote Start Wiring
genxmoto
Member - Posts: 8
Posted: May 29, 2007 at 8:43 AM / IP Logged
hello
does anyone have a wiring diagram to install a alarm on a 2004 nissan almera it looks like a nissan sentra but im not sure
this car is in costa rica and im going to install a k-9 classic-E when i go to costa rica as a favor to a friend for helping me out
thanks
GenX
Genx Motorsports and sound
Your source for your listening excitement!
xtremej
Gold - Posts: 1,440
Posted: May 29, 2007 at 11:08 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - NISSAN / ALMERA (UK) / 2002 / Remote Start
[PRINT THIS PAGE]
12volts
Starter BLACK/ white + loom to column
Second Starter
Ignition BLACK/ red silver bands + loom to column
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+
Parking Lights-
Hazards
Turn Signal(L) GREEN/ YELLOW - brown connector behind clocks
Turn Signal(R) GREEN/ black - as above
Reverse Light
Door Trigger RED / white silver dots - drivers kick
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometerblue/orange ac white connector at clocks
Wait to start
Brake WireRED / green + drivers kick
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
2004 Nissan Almera Alarm/Remote Start Wiring -- posted image.
Interface Modules: Not Available
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
This is all could scavenge, they didn't have a 04 listed. Hope this helps a little.
Jeremy
xtremej
Gold - Posts: 1,440
Posted: May 29, 2007 at 11:09 AM / IP Logged
Second Starter
IgnitionBLACK/ red silver bands + loom to column
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+
Parking Lights-
Hazards
Turn Signal(L)GREEN/ YELLOW - brown connector behind clocks
Turn Signal(R)GREEN/ black - as above
Reverse Light
Door TriggerRED / white silver dots - drivers kick
Dome Supervision
Trunk/Hatch Pin
Hope this helps ya ou all they had was for 02 almera (uk)
genxmoto
Member - Posts: 8
Posted: May 30, 2007 at 10:27 AM / IP Logged
thanks for the info
i found some clues on the almera. alot of the parts that the nissan almera uses also can be used on the b15 nissan sentra so im giong to send my friend info on the 2004 nissan sentra
again thanks for the help
GenX
