amp will not power
feelthebeatnow
Posted: May 29, 2007 at 3:10 PM / IP Logged
The amp will not turn on in my car but did in a bench test. All the power readings came back good, the amp will not complete the power circuit when all wires are connected to the amp. HELLLLPPPP
xtremej
Gold - Posts: 1,440
Posted: May 29, 2007 at 3:38 PM / IP Logged
Get out your meter, check your ground, check your power from the battery, then check and make sure your have 12 volts from your remote turn on wire.
deemo
Member - Posts: 11
Posted: June 11, 2007 at 4:43 AM / IP Logged
check if the fuse is ok if yes recheck all wiring especially the remote on your headunit!!!!
deemo
deemo
dswift
Copper - Posts: 396
Posted: June 11, 2007 at 3:48 PM / IP Logged
clean your battery terminals! might have corrosion.
"dont ground out!"
