confused about high output alternators.
adamhj
Posted: May 30, 2007 at 11:54 AM / IP Logged
I have a 04 ford F150 with tow package. I have learned that I have a 110amp alternator, and I have no idea if it is at idle or at some certain RPM. I am pretty sure I need 192amps to run my equipment (added amp fuses @ 130amps + head unit @ 15amps + added equipment fuses @ 17amps + average vehicle draw @ 30amps = 192amps), so that leaves me 91amps short. I am now shopping for a high output alternator and I found one on Ebay that states that they are selling a 200+ high output alternator but the output at idle is 105 amps, and that the maximum output of 200+ amps is achieved at 1200 engine RPMs. Would this be a sufficient alternator? Or should I shop somewhere else. I am concerned about this alternator being only 105 amps at idle where I need 192 amps to operate. At idle do high output alternators operate at lower amp as specified?
adam
haemphyst
Platinum - Posts: 5,059
Posted: May 30, 2007 at 12:36 PM / IP Logged
You're not going to find a 200A @ idle alternator, not for any kind of cheap money...
90% of your listening is probably above 1200 RPM anyway, so go with the one you found on FleaBay. Be careful, tho...
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
