window nightmare
steel-reserve
Member - Posts: 16
Posted: May 30, 2007 at 12:42 PM / IP Logged
Hello.
   WEll, here's my story..
I was going to make my friends windows automatically go up and down with his car alarm remote..   so anyway.. i opened up his door panel and started testing wires to see which ones i was gonna cut. so i decided to just start with the front two. (Just to go up for now)..   so i found the correct wires and all.. cut them, and then connected the two ends to a relay, so it was like it was never cut.. well anyway.. i decided to send live power to one end to test and see if this will make the window roll up.. (which it did) but at the same time, i got a burnt smell in the "window switch" (the driver window buttons that control all windows from that side.)
   The window still rolled up, so I was like, cool. but then I noticed that now the driver side window will not go down, (BTW I only tested the driver side window first) . So now i'm in a pickle! :)   I thought that maybe it was the whole window switch, but a friend of mine has the same kind of car and we swicthed the window switch with his and still no luck. :(   So if some one has any idea, please lemme know. Thanks! BTW
The Car is A 1999 Chrysler 300M V6 3.5L.
enice
Silver - Posts: 857
Posted: May 30, 2007 at 10:20 PM / IP Logged
how do you have it wired?
steel-reserve
Member - Posts: 16
Posted: May 31, 2007 at 10:33 AM / IP Logged
thats the thing.. i never started to mess with it.. as soon as the window didn't go down, i stopped and put everything back to normal, but still not able to roll the window down.. maybe the window regulator?
KPierson
Platinum - Posts: 3,527
Posted: June 01, 2007 at 10:00 AM / IP Logged
Do the other three windows work?  How exactly did you wire the relay and what wire color did you wire it in to?
Kevin Pierson
KarTuneMan
Platinum - Posts: 7,056
Posted: June 01, 2007 at 1:11 PM / IP Logged
NOT good.....
DRIVER WINDOW UP Lt.blue At window switch in driver's door   REV POL
 DRIVER WINDOW DOWN White At window switch in driver's door   REV POL
 PASSENGER WINDOW UP BROWN / white At window switch in driver's door   REV POL
 PASSENGER WINDOW DOWN PURPLE / white At window switch in driver's door   REV POL
 LEFT REAR WINDOW UP Dk.blue/white At window switch in driver's door   REV POL
 LEFT REAR WINDOW DOWN RED / black At window switch in driver's door   REV POL
 RIGHT REAR WINDOW UP Gray/black At window switch in driver's door   REV POL
 RIGHT REAR WINDOW DOWN Dk.GREEN / WHITE At window switch in driver's door   REV POL
I don't know if this helps? I have never gotten into rolling windows up/down with a transmitter. (the switches on the doors are enough for mewindow nightmare -- posted image.)
steel-reserve
Member - Posts: 16
Posted: June 01, 2007 at 3:17 PM / IP Logged
cool.. thanx.. that might help...   also.. does anyone know how to find a short if there is one?? thanx in advance
steel-reserve
Member - Posts: 16
Posted: June 01, 2007 at 3:22 PM / IP Logged
i ASK becuz, i took the car to a shop and they told me that it was the "window swicth" and a short in the wire.. (driver side only) so yeah, how would i go about looking for the short?? :)
KPierson
Posted: June 01, 2007 at 3:40 PM / IP Logged
It sounds like you ran 12vdc directly back in to the window switch (rests at ground).  If you did this, it would have burnt the traces off of the circuit board (if there is a board).  Since the system rests at ground there isn't a fuse to protect it.
However, since you swapped out the switch I would say that that isn't the case.  What you need to do is make sure both window wires REST at ground still.  Then, one wire at a time, make sure there is 12vdc on the up and down wire for that window.
Kevin Pierson
steel-reserve
Member - Posts: 16
Posted: June 04, 2007 at 1:48 PM / IP Logged
COOL.. thanx for the info man... so once i find the short.. (and i am determined) :)   how do i go about fixing the problem? do i follow the wire all the way into the car? sorry for the stupid question, but i promise i only ask 1 stupid question a day.. (try to make it a point) :P
anyway, thanx again for all the help peeps!
peterubers
Silver - Posts: 706
Posted: June 04, 2007 at 1:59 PM / IP Logged
do the other three windows work?
The search function is your friend.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
