two starter motor wires
steezs
Copper - Posts: 172
Posted: May 30, 2007 at 1:25 PM / IP Logged
Can a car have 2 starter moter wires? if so do you have to cut them both and put a relay to each for the alarm to stop the car from starting?
the duce
enice
Silver - Posts: 857
Posted: May 30, 2007 at 3:07 PM / IP Logged
Both would need power for remote start.  As for the cut off, cut the main starter and see if it still cranks.  If it does then you would just have to use a relay for the second starter.  Never connect to each other.  If the car still cranks then you would use relays for both.
Sunday, October 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
