aga1201 in 1990 gmc
samz
Posted: June 05, 2007 at 7:09 PM / IP Logged
i recently bought a aga-1201 for my 1990 gmc full size pick up, same alarm as in this post https://www.the12volt.com/installbay/forum_posts.asp?tid=88545 .
i am having a problem hooking up the keyless entry also, i can't seem to hook it up with out blowing the fuses. i treid relays and every possible combo i can think of.
any help would be greatly appreciated
KarTuneMan
Platinum - Posts: 7,056
Posted: June 05, 2007 at 7:20 PM / IP Logged
Try this way..... Chances are you have the switch and the motor wires backwards... (on the wrong pins of the relay)
aga1201 in 1990 gmc -- posted image.
samz
Posted: June 05, 2007 at 8:44 PM / IP Logged
i tried that but i don't know which wires on the alarm are the (-) outputs
https://i178.photobucket.com/albums/w247/monetxgirl/alarminstructions.jpg
On the alarm there is a 10-pin connector primary harness.
the pin are as follow (by manual)
pin 1: brown wire:siren output (+)-this is obvious for me
pin 2: white wire: parking light output (+/-) relay. do i need a relay then and then connect the relay to the parking light? or can i just connect it directly?
pin 3: violet: unlock #87a normally closed
pin 4: blue/black: unlock #30 common (output)
Pin 5: BROWN / black: unlcok #87 normally open (input)
pin 6: violet?black: lock #87a normally closed
pin 7: GREEN/ black:lock #30 common (output)
pin 8: WHITE/ black: lock #87 normally open (input). pin:
9: red constant
pin 10:black system ground
