1993 Dodge Caravan, tach
knifegrinder
Posted: June 08, 2007 at 11:07 AM / IP Logged
I have a 1993 Dodge Caravan with a 2.5 liter 4 and a 5 speed. I bought a tach and it says to hook the green wire to the negative wire on the coil. Can you tell me which wire is the negative? Does this car have that Hall effect ignition? The coil is a different shape than most. Thanks for any help.
Twelvoltz
Platinum - Posts: 2,384
Posted: June 08, 2007 at 5:46 PM / IP Logged
https://www.the12volt.com/installbay/alarmdetail/672.html
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
