2001 chevy astro van wiring
mts1
Posted: June 11, 2007 at 12:24 PM / IP Logged
Hi All
I have a 2001 Chevy Astro Van that currently has a Python 1500 ESP Alarm/Remote start System that I would like to replace witha diffrent system because all the wiring is already in place and working I would like to use as much of the old setup as possible. Does anyone have a copy of the Python 1500 ESP Install Manual or wire diagram it would be helpfull to trace back the old wiring.
Thanks Frank
Frank G
mts1
Posted: June 12, 2007 at 5:21 AM / IP Logged
looking for the Alarm and remote start diagram along with power window up and down wiring for a 2001 chevy astro van
Frank G
rudydapimp
Copper - Posts: 390
Posted: June 12, 2007 at 8:53 AM / IP Logged
12volts      red & RED / white       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter
Ignition      pink       +       ignition harness
Second Ignition      white       +       ignition harness
Third Ignition
Accessory      orange       +       ignition harness
Second Accessory      brown       +       ignition harness
Keysense
Power Lock      lt. blue       +       drivers kick panel
Power Unlock      white       +       drivers kick panel
Lock Motor      gray             drivers kick panel
Unlock Motor      tan             drivers kick panel
Parking Lights+      brown             drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      see notes       -       BCM above climate controls
Notes: There are 4 separate door trigger wires. You must use all 4 wires and diode isolate each. The drivers door is blue in the purple plug pin B4. The passenger front door is orange in the purple plug pin B2. The sliding door is pink in the lt. blue plug pin B10. The rear door is yellow in the lt. blue plug pin B11.
Dome Supervision      gray/black       -       relay above diagnostic plug
Trunk/Hatch Pin      see door trigger notes
Hood Pin
Trunk/Hatch Release      lt. blue       -       relay above diagnostic plug
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      white             PCM
Notes: The PCM is located below the battery.
Wait to start
Brake Wire      white       +       brake switch
Parking Brake
Horn Trigger      black       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Combo Interface      Required:
Yes      Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays: Not Available
LF Window Up     DARK BLUE     (REV)          RIVERS WINDOW SWITCH
LF Window Dn     BROWN          (REV)          DRIVERS WINDOW SWITCH     RF Window Up     BLUE/WHITE     (REV)          DRIVERS WINDOW SWITCH     RF Window Dn     TAN          (REV)          DRIVERS WINDOW SWITCH
rudydapimp
Copper - Posts: 390
Posted: June 12, 2007 at 8:55 AM / IP Logged
https://www.the12volt.com/installbay/file.asp?ID=431
credit given to uploader - swamprat!
